Phillips 42OFL3704D/F7
    When power button us pressed.. I hear a click & front indicator light turns white but has no picture or backlight.
    Any ideas?
    Re: Phillips 42OFL3704D/F7
    Subject Should be 42PFL3704D/F7
    Any ideas?[/QUOTE]
      bump.....
        Bump... thanks for any info.
          https://www.badcaps.net/forum/showthread.php?t=39740
          There are more than one version of this model.
          http://www.shopjimmy.com/catalogsear...2PFL3704D%2FF7
            try to post some pics., of your boards, I'd start with checking the fuse on the power supply board, careful power supply has high voltage.
              Thanks for the replies. I attached a picture & hope it tells you a idea what may be wrong.
                I thought I better post clearer pictures.
                  Did the pictures give any ideas what the issue may be? Thanks
                    Do you have a digital multi-meter?
                      Hi... yes I do...
                        bump...
                          There doesn't look to be much info on this set. If your power supply has labels at the connectors for the expected voltage, I would prove each pin at each connector to look for that expected voltage. Personally, I suspect your main board, without knowing what the expected voltages on each pin are, I can't really help you with any guidance.
                            Please upload the pictures of the whole back side of the TV so I can see all the boards.
                            Check to see if you do have 24Vdc on any one of the red wires (black probe on the chassis) on the white connectors which should go to the inverter board.
                            https://www.badcaps.net/forum/attach...0&d=1418779596
                              try to grab a manual, if the power supply board isn't labeled with expected voltages where connectors go, if the voltages are correct, then power supply is prob. good.
                                my phillips had blown capacitors on inverter board.
                                  BTW, is the TV actually is 42PFL3704D/F7, not Phillips 42OFL3704D/F7.
                                  Service manual for 42PFL3704D/F7
                                    Any ideas?
                                    [/QUOTE] yes
                                    42PFL3704D/F7, typo in title.
                                      Did anyone ever figure out what this issue was? I have the same TV with the same problem.
                                      I checked all the voltage going from the inverter board to other boards, all seem to be correct.
                                        To elaborate a bit more, when I plug in the TV or turn it on, after about 7 seconds there is a brief flicker on the front of the TV then it all goes dark.
