Can't Melt Solder on Power Board
    I am changing a bunch of capacitors on a power board in my 47pfl7403d/f7 & cannot budge any solder. I've tried adding new solder with no luck. My Hako iron is at 750. Thanks for any help.
    Re: Can't Melt Solder on Power Board
    A small tip donĀ“t have enough power to heat a big surface . Do you have a heat gun ? if so you must heat the whole area before using the iron . Then put some new lead solder to make it easier .
      Dont solder with a heatgun , you might destroy other parts.
      You need a good solder iron. 85W solder iron is more then enough to desolder capacitors.
      You probably need a bigger tip otherwise the board will take all the heat and the solder wont melt....
        I'd suggest, first add more solder to cap legs then use sucker pump .
          heat the whole area BEFORE using the iron
            try adding flux . what caps are they ? like are they through hole ?
            fit larger tip . 2 or 3mm i think .
              I got the solder to melt.... I needed to reset the Hako unit & was fine. Thanks for the replies.
