Dell U2312H Repair
    Dell U2312H Repair
    I have a Dell U2312H that suddenly won't turn on anymore. The display and
    backlight won't turn on; the blue power LED stays off even when I press the
    power button. These have the L0281-1N power boards which are the same ones used
    for the Dell P2312H and P2012H, among others (according to Google).
    Unfortunately I can't find any schematics for this particular board.
    I have made some measurements to some of the components from the power board
    and main board. These were all tested in circuit (i.e. I didn't solder them
    out). Readings are ordered by pins (e.g. 1, 2, 3, etc.). Diodes were tested
    using the continuity tester of my multimeter; however, I don't know what the
    units for these are. I have upload the images of the boards to imgur. If you
    need a close up picture of some parts of the board, please don't hesitate to
    notify me. Thank you!
    Power Board
    I805
    AUK
    81826
    A78R12PI
    12v, 0.8mv, 0v, 0.263v
    I802 (Optocoupler)
    L1125
    817D
    Y
    Red to Pin 1 + Black to Pin 2: 567
    Black to Pin 1 + Red to Pin 2: 567
    I801 (PWM Controller)
    LD7575BGS
    112731
    Pins 1 - 4: -0.48v - -0.58v
    Pins 6 - 8: -0.35, -0.02, 0.66
    Q121
    D482
    BA1U15
    Black to S + Red to G: 16.31MΩ
    Black to S + Red to D: 0.82MΩ (and increasing)
    Black to G + Red to D: 1.11MΩ
    D805
    pec 1329
    ER1002FCT
    Black to Pin 1 + Red to Pin 2: 581 and increasing
    Black to Pin 1 + Red to Pin 3: 001
    Black to Pin 2 + Red to Pin 3: 395
    Black to Pin 2 + Red to Pin 1: 395
    D812
    pec 1349
    ER1002FCT
    Black to Pin 1 + Red to Pin 2: 892
    Black to Pin 1 + Red to Pin 3: 002
    Black to Pin 2 + Red to Pin 3: 399
    Black to Pin 2 + Red to Pin 1: 399
    D810
    N 1G
    FCQS20A065
    Black to Pin 1 + Red to Pin 2: 481 and increasing
    Black to Pin 2 + Red to Pin 3: 135
    Black to Pin 2 + Red to Pin 1: 135
    Q803
    A
    2761I
    124 125
    Black to S + Red to G: 0.148MΩ
    Black to S + Red to D: 1.2MΩ
    Black to G + Red to D: 1.4MΩ
    R811
    1.1Ω (should be 0.36Ω 2WJ)
    Main Board
    I301
    N252
    G1084-33
    0v, 0.18v, 5.0v
    I302
    UTC
    LD1117AG
    12A010GTG
    0v, 0v, 0.18v
    I308
    D|| 1fB
    17-33
    0v, 0v, 0v
    Re: Dell U2312H Repair
    I am also attaching the images in this post. So sorry for using another image hosting site.
      "I301
      N252
      G1084-33
      0v, 0.18v, 5.0v"
      So you are getting 5V feeding this 3.3V Regulator but the out put is only 0.18V, it can be bad regulator or the output pin is over loaded.
      You should check the resistance between GND and the output pin to see if it shows very low resistance (<50 Ohms).
        budm, I have different readings based on the polarity of my probes:
        Black on GND + Red on Vout: 1.336KΩ
        Black on Vout + Red on GND: 0.353KΩ
          Those are OK, nothing <50 Ohms.
          So at this point that 3.3V regulator is probably bad.
            Do you have any idea why it went bad? I'm wondering if and what components up the chain that might have caused I301 to go bad.
            How about I802? I read that I should only have one reading for the LED pins; but I was able to get a second reading, with the polarity reversed.
              Not really. Sometimes they just die. Old age perhaps.
              Replace it and see what happens.
              Yes the LED inside the optocoupler should only test OK one way, but you are testing it in-circuit. Another part in parallel with it may well be causing a spurious reading. You would have to remove it and test it out-of-circuit to be sure.
              -David VanHorn
                I302 get the 3.3V INPUT from the output of I301, so you need to replace the I301 first.
                These regulators do fail, lot of them in VIZIO TVs, monitors..
                You should also check the capacitance/ESR or replace those filter caps on the input and out side of those regulators.
                  Hello everyone. The parts I ordered finally arrived yesterday. @budm was right, I only needed to replace the 1084-33 chip to make my monitor work again.
                  Although the monitor already worked without replacing the capacitors, I changed all of the electrolytic capacitors anyway since they were from a known bad manufacturer (Su'scon).
                  Thank you everyone for the help.
                    Thanks for the follow-up.
                      You forgot to check el.cap. ...
                        Just a shout out to doomsweek, I have the same monitor that was occasionally not powering up, initially I was looking to replace all the caps and then when googling the power board I found this post. My 3v regulator seems to be intermittent, currently I have hard wired a small ebay sourced switch mode regulator module set to 3.3v and it is currently working perfectly - just awaiting a new G1084-33 that is on order (stupid shop in my country says I need to order minimum 20 units though)
                          Pardon the newbie question.
                          Where is this G1084-33 located, is it the ic on the top right corner, when looking on the power supply board from the bottom?
                          If so why does mine say D482 GA2428 on it?
                          Got same screen\power supply issue, figured I'd try this cheap fix before I spend on a whole new power supply board.
                            post #1
                            Main Board
                            I301
                            N252
                            G1084-33
                            It is on the main logic board.
                              Duh moment, sorry.
                                CHeck the voltage output of the regulator first, if it is giving 3.3v then this is not your issue. I actually replaced mine by wiring in one of these https://www.ebay.com/itm/MINI-3A-DC-...0BF~:rk:3:pf:0 configured to output 3.3v
                                The monitor ran fine for three weeks like this while I waited for the correct ordered part. I suspect that it would have run indefinitly with this as well
                                  Good evening, forgive me if I insert myself. There was a short on my power board and some components exploded. Could you indicate the values of r815 and zd801? thanks a lot..
                                    seems to be a common shit problem..
                                    i have one at home..... after power off the mains.... very hard to on back...
                                    need to leave on the mains for some time... around one hour to bring the monitor to on again.
                                      Hi guys. I have this problem too with my monitor. I have one question, is it normal the voltage output and input at I301 are intermittent but are in spec?. Let say 5V input and 3.3V output are reached, but it not consistently. Drop and get again with tickling sound at power board.
                                      Sorry for my English
                                        Good day everyone. I had a similar problem with my dell 2212hm rev.6A. One day the monitor just wont turn on. I checked the power supply and everything was working. I did check this regulator g1084-33 and there is no voltage on the output. I replaced this regulator and my monitor is back to life. Thank your for the tips.
