Eeprom dump thread!
This is a sticky topic.
    Re: Eeprom dump thread!
    [QUOTE=arizanotlari;952488]his shared my archive.
    https://yadi.sk/d/sl-k5xvJUQhpHQ usb firmware
    https://yadi.sk/d/AAU9Mluqbwb7Qg flash dump[/QUOT
    Thanks a lot ... but why he give me this message when programming ..
      Disable auto verification.
      https://www.badcaps.net
        how ı do this ??
          setting-programing setup options menu
            Does anyone have a USB firmware image for 17MB211 (panel: VES480UNDS-2D-N12)?
            The TV model is Bush DLED48287HDCNTDFVPY.
            Thanks.
              The process is done ..... Thanks again my friend ..
                Hello i need firmware for hitachi tv 48hb6w62a chassis 17mb110p
                  Hi.
                  Try this
                    Please Help CH341A Software Programer for HP Laptop DV3-4036TX,
                    i need flashable file, the file i have from HP web is too big for CH341A. do any one have away to make it became programable or the memory location for capturing from original flash file.
                    would appeciated the help.
                      Hello i try with usb,i format the usb fat32,i copy all the bin but is not workingk.the led is flashing and the screen is black the same syptom.
                        mst6m182vg-v1.2 panel :lc370eun-sem1 plase frimware
                          Re: nand philips
                          je cherche vidage nand philips model 37PFL4007K/12
                          chassis Q552.4E LA
                            LG 43LH5100-ZE
                            EEPROM IC104
                            Type 24C256
                            Panel HC430DUN-SLVX1-511X
                              Re: nand philips
                              chassis Q552.4E LA
                              here :
                              https://we.tl/t-YXza91t9xf
                                complete code of the display ?
                                  hello dump file for eeprom the led flashing no power on
                                  the display is ves480unds-2d-n12
                                    I need the firmware for a Samsung UN40EH5000FXZA Ver. HS03.
                                    Thanks,
                                    Tony
                                      Hi there, i need Sharp Aqous LC-32X20E eeprom bin file,,common problem on this model blinking red and green led... Thank you in advance , Big regards
                                        Try this
                                        http://www.opendrivers.com/modeldriv...-download.html
                                          DUMP O BIOS PARA TV RCA MAIN Tp.ms3393.p83 RCA RC-40M1-A
