Eeprom dump thread!
This is a sticky topic.
    Re: Eeprom dump thread!
    Thankyou for sharing this info and dumps
      thak u
        Hisense ltdn 22w11 uk
        Main Board : MSDv3212-zc01
        Flash: W25Q32BV
        CPU: MSD306pt-lf
        FIRMWARE DOWNLOAD:
        https://goo.gl/eR1gaq
          T.V56.03 All Resolution
          Main Board: T.V56.03
          CPU: TSUMV56RUU-Z1
          FIRMWARE DOWNLOAD:
          https://goo.gl/h2gFmC
            Main Board: TP.MS338.PB801
            Résolution : 1920x1080
            FIRMWARE DOWNLOAD:
            https://goo.gl/XuMvu1
              Funai LED TV 29FL553/10N
              It's working! New FLASH chip helped!
              Thanks a lot for sugestions! Especially diif
              Below I uploaded FLASH Dump for this TV (thanks to zdzifu from elektroda.pl forum):
              FUNAI 29FL553/10 (mine was 29FL553/10n)
              Motherboard: T.MSD309.B95
              Flash 25Q32BSI
              Submitted by Folxs
                Résolution : 1366x768
                Panel : LC390TU1A
                FIRMWARE DOWNLOAD :
                https://goo.gl/wrfYyE
                  Universal LED
                  Main Board : T.VST59.031
                  CPU: TSUMV59XU-Z1
                  FIRMWARE DOWNLOAD:
                  https://goo.gl/EMFyQE
                    CV338H-A32_1366x768
                    Résolution _1366x768
                    FIRMWARE DOWNLOAD :
                    https://goo.gl/bvYFpq
                      Universal Board LED TV
                      Main Board :T.V56.A8
                      CPU : TSUMV56RUU-Z1
                      Tuner :R842
                      SPI: 25Q32
                      Firmware Download :
                      https://goo.gl/iqzkt1
                        here is the eeprom dump i took from an "emerson lf501em4 a" with a broken screen. it was a windbond chip.
                          EEPROM for a Vizio VO420E tv.
                          Main board: 3642-0732-0150(0C)
                          Replacement EEPROM markings:
                          Code:
                          MXIC MX
                          25L3206E
                          M2I-12G
                          3T871700
                          KT60576
                          -Thomas
                          I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
                            Toshiba 32KV501B firmware needed.
                            Has anyone got the update firmware archive for a Toshiba 32KV501B. It appears to have been removed from the toshiba support site?
                            Thanks.
                              Re: Toshiba 32KV501B firmware needed.
                              Thanks.
                              Maybe worth contacting toshiba they may send you out the firmware on a usb stick i beleive this is the number 01246 7780
                                Thanks Vince. But I don't have a viable s/n though as the info plate has been damaged and i'd imagine they would look for one ?
                                  if your sure its a firmware issue and cant find free one online maybe use these there a good company
                                  http://www.ohmsupplies.co.uk/EEPROM-...-32KV501B-U390
                                    Thanks Vince. I'll keep ohms supplies as a last resort. with shipping etc it would be closer to 30e not worth it for this 32 inch. obviously a download
                                    would be better
                                      would be better
                                      whats the mainboard model number used in this set and whats the lcd panel number used in this set
                                        A Vestel 17mb60 v4.1 panel LTA320AP06. I would imagine this combination is used in a variety of makes ie. Nordmende NM3296M4, so it may be worth using one for a different model? I wouldn't mind a dilfferent logo or menu I think the reason it's gone from the toshiba site is because I think the service menu allows tweaking screens etc so their software was probably used on different makes
                                          i have asked on another forum im a member of ive been sent this so its up to you if you want to try it sent you a pm with the link as wont let me upload the file
