Remove_SMM... UEFI.
    Re: Remove_SMM... UEFI.
    Edit.... last model? T490, T590???? Any solution?
      This Patch not supported t490 t590!
      I found ebay sales 9th gen bios unlock.
      If someone buys it, please share it
        Where is link?I have some lock laptop want to buy if trusted guy.
          Hi, can somebody help with T560 password.
          I tried to replace the two files, but I get black screen and 2x5 beeps.
          Thanks.
            Reliable. Unfortunately, I do not know.
            I'm interested Bios patch.
            This is link
              Thanks.
              Patched this Bios file.Please feedback to me
                This is link
                This can be a scam, allservice does not fix 9th generation.
                This link
                  Thanks. All ok.
                    Originally posted by bjhawfam View Post
                    When I compare lenovotranslateservice and bootoption they come out the same in hex editor extract. Why does the patch I created not work compared to yours?
                    NEVERMIND I found it.. I was able to compare several files on here and found the changes.
                    FINALLY!!!! After comparing the files and using both a hex editor and UEFITool I was able to find my problem. I then used the original file and made a patch as well. When I run a comparison it comes back exactly as the patch xdrive55 created. Just had to replace one last region and BAM.. Will have to try it out. Thanks for your help xdrive55 and for all who posted in this tread that contributed.
                    please kindly post the full tutorial bro
                      You have everything on this tread,read carefully.
                        Hi Guys,
                        Could you please help me unlock those two bios for Lenovo ThinkPad X1 Yoga 2nd Generation ?
                        Type: 20JE-S4FN01
                        Type: 20JE-S45V01
                        Thank you in advance.
                          Originally posted by naonao View Post
                          Hi Guys,
                          Type: 20JE-S4FN01
                          Type: 20JE-S45V01
                          Patched this Bios file.Please feedback to me.
                            get Hardware id: 1612452998
                            enter key : 1234567
                            Worked like a charm for the first laptop.
                            I will try with the second one.
                            Thank you so much.
                              Hello, I've tried patching a Lenovo X1 Carbon Gen 6 to no avail. I'm always getting an 8 beep error code and a blank screen. I want to know if its just about replacing the modules or additional steps have to be taken. I had an earlier X1 Gen 6 patched successfully in this forum (thank you dani981).But when I use that bios file, it gets to where I press F1 to enter setup and then it writes "entering setup..." and then nothing happens. I extracted the modules from the earlier patched bios and used them to patch this current X1, but all I get is 8 beeps. I want to know if UEFI Tools alone is enough. I will be grateful if this file will be patched for me. Thanks in advance.
                                Try this:
                                  Try this:
                                  Hello, and thanks for helping, but I am still getting 8 beeps..
                                    can anyone patch this one
                                      Pls help me with patching x260 bios
                                        Hi! pls help me with my t440! Thanks!
                                          Try
