Jvc TH-D258B No power on standby led
    Hi, Guys, I have 16v from the power board going to the audio processing board but not sure what to check after this to diagnose the problem
    Any help much appreciated
    Your never to old to learn
    Re: Jvc TH-D258B No power on standby led
    So the how many Voltage outputs are there from the power supply board, just single 16V output?
    Pictures of the power supply board?
      Thanks budm for your reply yes only on output from the power supply and I have attached pictures of the power supply
        https://www.badcaps.net/forum/attach...0&d=1581605478
        OK, that means the main board has the Voltage regulators, and buck converter to change the 16V to lower Voltage to run the processor.
        I see at least one switching power section where the black inductor with '150' printed on top, I would check the Voltages between the two legs of those SMD Lytics caps to see if they show any Voltages.
        You should also upload the pictures of the bottom side of the main board, there may be some linear regulator IC's on the bottom side too.
          Hi Budm thanks for your info I have 5v on both sides of the cap and I have uploaded a pic of the bottom of the main board
          Thanks for your help
            Anyone any idea what the next step would be to find out the problem.
            Thanks in advance
              Anyone plz
