Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Audio Equipment
Thread Tools Display Modes
Old 10-28-2020, 07:10 AM   #1
FrozenHaxor
City & State: Warsaw
My Country: Poland
Line Voltage: 230VAC 50Hz
I'm a: Professional Tech
Default Denon AVR-X2000 no audio after blown channel, no bias current.
I'm repairing a Denon AVR-X2000 that has blown both FR channel output stage transistors. Upon replacing the transistors (Q416 and Q422) witch a matched pair and replacing both burnt 22Ohm base resistors (R458 and R483) the unit powers up and I was able to set idle current to spec (8mV on test points) across all channels except for the FR channel that had a problem, it tests 0V and I'm unable to adjust that at all. The transistor (Q421) which regulates the bias current tested okay (it sits between the big transistor pair). Also I'm unable to produce any audio from any channel. I have tested all main power rails and they check out fine, output transistors are getting their positive and negative ~40V rails as well.
Has someone came across such issue? I would assume that audio would come out of any other channel except the one that still doesn't fully work. Could something upstream that produces the low level signal be blown? Never came across that. Any hints appreciated, apart from amplifier block, the rest of the unit is pretty much impossible to test due to joined board construction that pretty much make a full box with no access.
I have uploaded service manual to my private server due to attachment size limit: http://frozenhaxor.pl/avre400.pdf
Thanks!
FrozenHaxor is offline   Reply With Quote
Old 10-28-2020, 08:50 AM   #2
R_J
City & State: ☻
My Country: Canada
Default Re: Denon AVR-X2000 no audio after blown channel, no bias current.
If the base resistors were open, I would check all the other resistors and transistors in the drive circuit, also are the output emitter resistors ok?
Check the voltage at the common point of the output resistors (dc offset) this should be near 0 volts, if it is not it will not allow any of the speaker relays to connect to the speakers, so no audio from any channel.
R_J is offline   Reply With Quote
Old 10-28-2020, 09:04 AM   #3
tibimakai
City & State: Los Angeles/San Dimas, CA
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Knowledge Seeker
I'm pretty sure, that there are more components that are bad.
tibimakai is offline   Reply With Quote
Old 10-28-2020, 03:46 PM   #4
FrozenHaxor
My Country: Poland
Thanks, turns out I missed one emitter resistor pair. Not sure how, must have measured only one pair by mistake. Everything works fine now, bias current is set and regulating properly with temperature. Audio output is good.
Quote:
If I didn't know that, I wouldn't be posting
Old 10-28-2020, 04:05 PM   #5
R_J
City & State: ☻
My Country: Canada
Glad to here you have it working.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
