Old 10-29-2020, 04:24 AM   #1
stingerchamp
City & State: Pakistan
My Country: Pakistan
Line Voltage: 230 VAC 50 Hz
Post HP OMEN AX236TX DAG35DMBAD0 rev:D NO power no light
HP OMEN AX236TX DAG35DMBAD0 rev NO power no light.
Hi ,
This is another laptop with same problem in which there is no Power to the system while when checked for first two mosfet switching (19v rail area).
I am getting 18.2 volts at the gate of first mosfet PQ1002 and it is a P-channel mosfet.
PQ1002 first mosfet:
pins 1,2,3=19volts , pin4=18.2 volts , pin5,6,7,8=19volts
PQ1002 gate is controlled by PQ1004 voltage divider circuit , if we calculate for voltage at gate of PQ1002 it should be around 15volts (due resistors 220K,1M) but i am getting 18 volts.
PQ1003 second mosfet:
pin 1 ,2 ,3=0 volts , pin 4= 0 ,
stingerchamp is offline   Reply With Quote
Old 10-29-2020, 08:16 AM   #2
mcplslg123
City & State: siliguri
My Country: india
Line Voltage: 220vac,60hz
Default Re: HP OMEN AX236TX DAG35DMBAD0 rev:D NO power no light
PQ1002 gate voltage is correct. 1M & 220K are not voltage divider circuit. Read the schematic carefully and try to understand it. You are not getting any voltage on PQ1003 pin 1,2,3 and thats your +PRWSRC-means 19V rail. What is the impedance on pin 1-2-3 of PQ1003?? Its likely to be shorted to gnd.
mcplslg123 is offline   Reply With Quote
Old 10-29-2020, 09:11 AM   #3
stingerchamp
Thanks for the input but this PNP Bjt dual array is there for some reason.
Old 10-29-2020, 11:25 AM   #4
SMDFlea
City & State: York
My Country: UK
PQ1004 datasheet - https://www.diodes.com/assets/Datasheets/ds30109.pdf
One area that you can study with a P channel mosfet is the Gate Threshold Voltage ,which can be very misleading. http://www.aosmd.com/pdfs/datasheet/AON7403.pdf
With no power attached chek PQ1002 in Ohms ,
red lead on drain,black lead on source. Ohms =
Black lead on source,red lead on drain. Ohms =
SMDFlea is offline   Reply With Quote
Old 10-30-2020, 12:14 AM   #5
stingerchamp
PQ1002
with only cmos cell
red lead on drain,black lead on source. Ohms = display OL
Black lead on source,red lead on drain. Ohms = display OL
PQ1003
red lead on drain,black lead on source. Ohms = 2.2
Black lead on source,red lead on drain. Ohms = 2.2
red on pin5 and black on pin4 gate = 195 for 1 sec than reaches L
Old 11-01-2020, 08:18 AM   #6
stingerchamp
hello
Old 11-02-2020, 08:57 AM   #7
stingerchamp
Question Re: HP OMEN AX236TX DAG35DMBAD0 rev:D NO power no light
In view of your private message , I have to change the multi meter because this one is a cheap one DMM and i can not perform Diode mode test(not supported) with this clamp multi-meter Dt-266 , I do not want to pull out anything from motherboard and have a desire to test the components while they are still in motherboard without any power attached. suggest any good DMM if any.
