Sony KLV32U300A starts up then shuts down with ared led blinking twice with a pause then again the same over,ould someone pls give advice on where to lookfor rhe error
Re: Sony KLV32U300A starts up then shuts down
Service manual.Attached FilesNever stop learning
Hi Dick no i hav'nt checked the voltages yet and i will post pics of the circuit boards,yesterday i switche the tv on and it actually came on for 5 minutes and switched off automatically but after that the same on off occured again.what can you make of that
Hi Dick,i checked voltages on standby and all seem ok but when i removed one plug from power supply going to the main board then green light stays on which indicates that the fault is on main board but the led flashes 2 times still which according to the chart of blinking codes should indicate that the psu is the culprit,how do i post pics of the boards on here
RJ gives an explanation on how to add attachments
https://www.badcaps.net/forum/showpo...18&postcount=4Willing to help but I'm no expert.
