Lenovo g70-70 AILG1 NM-A331 no power
    Hello have this Lenovo g70-70 AILG1 NM-A331 with no power. second p-mosfet have 20v on gate. i cannot find shematic. what to do?
    Re: Lenovo g70-70 AILG1 NM-A331 no power
    I found Lenovo g50-70 schematic maybe it does help as reference(?)
      NM-A271 could be somewhat similar.
        First thing is to make sure both DC-in MOSFETs are not shorted.
          if thez was shorted, i will get 19V after them
          second is P channel so some charging logic is bad
            i have ACDET, VCC, but no ACOK on BQ737
            replaced but still the same
              i jumped second mosfet and voltages looks ok even after press power button. but no post and power just jump to 8W
                MAYBE ite PROBLEM?
                  BQ737-ACOK is supposed to be low.So nothing wrong there i beleive.
                    If first DC-in MOSFET is fully shorted, both gates will have DC-in voltage on them, second MOSFET will never be turned on.
                      looks like u have right. first mosfet shorted between base and source. after replace power is good, but still no post
                        guys anyone can help with this?
                        after mosfet change, it self start. all voltages are good. cpu and gpu is heat, but no post. try to flash bios but no luck
                          Hello. please help! Lenovo G70-80 NM-A331 does not turn on. 3.3V, 5V okay, bios okay. Charges the battery. When the power button is pressed, the power white LED flashes only once and does not turn on. has anyone encountered such an error?
                            You can start by trying bios. Are the coil resistances and voltages normal, are there any heated parts.
                            I'm not happy to be so strong. because it's not humanly
                              I experimented, heated a video chip, and started the machine, it works. Motherboard bga error
                                I add schematic.
                                https://www.badcaps.net/forum/showthread.php?t=79220
                                Last edited by SMDFlea; 07-20-2021, 04:11 AM. Reason: Schematic moved to schematic requests section
