Asus UX510U issue with 8 keys on the Keyboard
    Re: Asus UX510U issue with 8 keys on the Keyboard
    any issues with external keyboard ?
      Originally posted by JG2018 View Post
      With an external keyboard it works perfectly.
      External keyboards are fine.
        I remain of my opinion that the replacement of the EC should at least be attempted. I do not believe that a reprogramming can solve the problem but it is still the first attempt to be made.
          Working perfectly with an external usb keyboard
            Do i need to replace exact same new IC or can place one of some other board with +- same information on the IC?
              It needs to be the same and it has to be programmed.
                Ok i see :s how do you program those kind of IC (what's the tool, program)?
                  You'd need an external programmer for this.. It would be better to get a new board if you don't have a programmer for those chips.. New (used) board would be the cheaper option unfortunately...
                  But confirm the connector first. It would be odd if only one pin of the EC dies.
                    Any progress here ??
                    i halve exactly the same issue
                    with the same laptop
                    Looks like the EC chip is busted
                      i have this issue before, and it was bad bios, try a clean me bios or another working bios, that should solve the problem .
