DELL Latitude 5410 bios not work
    Please help
    Bios of dell latitude 5410 is corrupted
    I test with another Laptop work fine but serial number is incorrect
    thank you for re-entering the correct serial number and the windows key please
    Original Serial :4VBTP73
    THANKS
    Re: DELL Latitude 5410 bios not work
    please can someone help me
      try... if it's not ok, post the bios serial that works..
        Not good , bad serial and locked bios
        I explained myself badly in the post above.
        My original bios is corrupted, I put another one for testing and the PC works now.
        but the numbers are not good.
        I need to put this number back to 4VBTP73
          try this one
            Originally posted by SMDFlea View Post
            try this one
            PERFECT, ALWAYS A GREAT JOB
            Thank SMDFLEA
              Thank SMDFLEA
                Re: Dell Latitude 5410 Bios Password 8FC8
                I have dell 5410 powers on no display, attached the original bios backup
                [Mod. Edit-Vesko356] Read the rules before posting:
                  Here's your New BIOS, try it and let me know.
                  Service Tag: F8QKZ33.
                  I don't know why you typed "BIOS Password" in the thread title!
                  all donations are welcome,
                    Because Motanya didn't read the rules and made his request in the wrong thread so I had to move it here, and next time he does something like that instead of moving it I'll delete it.
                    Become a Badcaps supporter
                    Thanks to all supporters.​
                      Sorry about the password issue. The issue is it does not display.
                      I have tried the bin you provided it does not work either
                        Hello everyone, I was not able to get a working bios for this Dell but I have seen here the same model has 16MB and 8MB instead of the 32MB. Can I replace the 32 with 16MB and 8MB and use Winbound soic (W25Q128 and 64)instead of XMC and it works?
                          N0
                          Upload your 2 bios dmp + your service Tag
                            St: F8qkz33
                              St: F8qkz33
                              9.1 KB !!
                              Try read again twice and verify , save it and upload here
                                the main one 32mb i uploaded above
                                  Dell Latitude 5410 BIOS Help
                                  Details of laptop below:
                                  Make: Dell
                                  Model: Latitude 5410
                                  Service Tag: 4TFYN73
                                  Board Model Number: FDZ41 LA-J372P Rev 1.0
                                  Issue:
                                  Laptop came in for BIOS password removal. I used my EZP 2010 which seemed to detect the chip okay, but it actually only read 16MB of the 32MB chip.
                                  I didn't know there was an issue, I kept the original dump (which I thought was fine). I then pursued the script method to remove the password and get in to manufacturer mode, but this didn't work once flashed back to the chip. I then flashed the original dump back and still doesn't work. After googling and browsing this site I realised the dump was supposed to be 32MB and obviously this is the reason why it failed.
                                  I have a CH341A arriving tomorrow.
                                  I realise I may be out of my depth in rebuilding it myself, so wish to ask for help with this. Many thanks in advance.
                                  Dump attached.
                                  To be clear, this is the original dump (password still needs to be removed too).
                                    Hello sir I have a Dell Latitude 5410 with single Bios chip, laptop has power on but no display, I tried many bios but no luck. Please correct my original bios. Thank you
                                    Model: Dell Latitude 5410
                                    FDZ41 LA-J371P Rev 1.0
                                    Service Tag: 1255Q73
