tv oled LG55EC900V no start
    hi, when I turn on the relay with the remote control it clicks, the voltages are present 3.5v-12v-24v but after 3 seconds the relay clicks again and the PSU goes into standby
    tank you
    Re: tv oled LG55EC900V no start
    a little help please
      Disconnect LVDS cable and try again, if no result try to start up with P-Only button on service remote.
        thanks, I had already tried with lvds cable disconnected without result, at the moment I do not have the remote control as soon as I find it I do the test
          Most problems I have read with these are shorts at the 24v side.
            True, 24V could be the problem. There could be a s/c in the t-con but aso the panel.
              E waste
                I disconnected both the t-con and the panel but nothing changes, after 3 sec the relay returns open
                  Need some good pictures of the back and the boards.
                    I performed the smps2 test by making the bridge between pins 1 and 3 (pwr-on) and one between pins 2 and 5 (drv-on) of P2300, connecting the power supply the panel shows in sequence the colors red, blue, green, white, full screen
