I have a 65b9 that is showing symptoms of a failed cof tab or
bad bond.
It flickers a double image on one side with horzontal black lines across.
I'm trying to find someone that has a garbage panel with extreme burnin .
i will need you to attempt to remove one side of cof tabs.
This will require heating the panel and separating the screen like a cell phone or cutting the back open .
I need to see if the oled functions like a lcd and will continue to work without causing a panel fault ect .
I might be able to tape the tcon connection .
It might be a bad memory chip on tcon or dirty connections.
I read the tcon is married, even when they replace the panel it comes with the tcon, id rather remove the cof tabs.
The black lines remind me of when i removed cof improperly and it left lines across the screen
If this is the case we can get alot of these oled working again then possibly get new cofs installed.
If you have a 65 b9, pm me !
bad bond.
