Extract bios password from EliteBook 840 G8 Bios dump, possible?
    Re: Extract bios password from EliteBook 840 G8 Bios dump, possible?
    I'm assuming that the stock BIOS image extracted from the official HP BIOS exe can not be directly flashed, right ?
    Also, should the patch in post #9 be used on both chips?
    And, how is this patch found? I mean is there work we can individually do to contribute to solutions on other laptops? I'd rather not just be a helpless leech like now...
      HP EliteBook 850 G8 unlock please
      hello guys
      i tried RC unlocker but it give me error to try with 16mb chip
      i read that i need a modefied dump to work . but i dont know how to mod it
      if anyone can help that would be awesome
      this dump is for the 32mb chip on the back
      and please tell me how it done so i dont bother you guys again
      thanks
        Re: HP Elitebook 850 G8 bios locked
        Originally posted by hoaca388 View Post
        Ofcourse . In the first boot, you have to go into bios setting for dissable all the security options.
        hopefully you can help me , and please tell me how
          Become a Badcaps supporter
          Thanks to all supporters.
            NvramActiveRegn section removed ??? thanks man i will try it
            you are awesome
              After flashing the bios and verifying the flash
              I got a 6 blinking caps lock led
              Which on hp website indicates a BIOS authentication issue
              Any suggestions??
                Check your process again, is it good to solder the bios chip to the motherboard, is the data written to the chip through the programmer guaranteed?
                  I did a mistake reading the chip , but i don't think it's going to effect
                  The chip is 3v and i tried to dump ut using 1.8v adapter then i realized it's 3v chip
                  But it read and write fine..
                  Is that a problem??
                    Yup it was a bridge solder joint 😥 and fixed and the laptop boots fine now with no password
                    Thanks my man❤️❤️
                      Thanks my man❤️❤️
                      Hello, I don't want to steal the thread but can you please indicate what IC programmer did you use?
                      Thank you
                        If you are doing this for one time, go for the cheap ones, and IF for a living or to learn further, medium price are OK, I use a tl866-ll plus, never had issues with it, except when I tried reading two wson chips at the same time. Consider this: you are messing with a several hundred dollar machine, do not expect everything to go OK with a cheap one, soldering skills are needed too, best not to use a clip nor wires. It makes more sense to take MOBO to a skilled phone repair shop, just for desoldering and soldering back. Takes them a few minutes, even seconds to take out chip.
                          Thank you
                          its a cheap ch341 3.3v moded programmer it does the job for me and i have 1.8v adapter also i recommend you to buy the new version (ch341a programmer v1.7)
                            i have 840 G8 locked, i need unlock (patch didn't work)
                              I can't unlock it either, perhaps post the other chip contents?
                                In the first boot you have to go into bios setting to disable all the security options for avoid activate " Absotute " or " computrace " feature.
                                  Re: hp elitebook 840 g8 bios password
                                  hi friend, I have a problem with this same laptop, when it enters windows a lock message appears, I send an image with the lock, can I correct this with the HxD program?
                                  Thank you
                                    hi Hoaca388, can you help me ?
                                      Elitebook 840 G8 bios unlock (Administrator Password)
                                      Can you help me unlocking the admin password for HP Elitebokk 840 G8? (i5 gen 11th)
                                      Dump attached, contains the BIOS and EC ROM;
                                      no luck with RCUnlocker
                                      Thank you!
                                        Re: Elitebook 840 G8 bios unlock (Administrator Password)
                                        hello,
                                        can you help me unlocking the admin password for hp elitebokk 840 g8? (i5 gen 11th)
                                        dump attached, contains the bios and ec rom;
                                        no luck with rcunlocker
                                        thank you!
                                        feedback reprogram only ec
                                          I tried using stock (locked) bios and your EC and laptop doesn't power on; Caps lock on and that's it;
