Samsung UN60J6200 No power up
    Re: Samsung UN60J6200 No power up
    It looks like BLU_PWM is .9V, is this correct?
      So, I would say you have bad backlights.
        you maybe right. cant get it into forced backlight mode. Today I suddenly got reading of 100v on center pin of that mosfet and diodes under it. Power cycle, then i get 500mV. On one power cycle it didnt automatically turn on like it has been, i had to use the power button to turn on. this unit is acting erratically.
          Fired it up on a 100w dim bulb tester, bulb flashes bright then dims every 3 seconds.
            ok, you see video, and have 388 on filter caps, must be the backlights.
              Can you post the part number for replacement. Thank you.
                  some info. from shopjimmy, they're kinda high priced there tho: https://www.shopjimmy.com/bn96-29074...strips-new-12/
                    some there, don't recall buying from them so can't actually vouch for them but they have 99% rating and decent price: https://www.ebay.com/itm/20384872651...Cclp%3A2047675
                      TY, that seller sold 130 units, must be decent quality. Ill give it a try and report back.
                        Installed new backlight LEDs. With panel disconnected from microcontroller, on dim bulb, the backlight lights up, but only momentarily as it flashes on and off every few seconds. The bulb remains is dim in this case.
                        With panel attached to microcontroller the dim bulb flashes bright after the flash of the backlight. I do see blue LEDs light up on the TCON board now but only momentary before backlight flashes off.
                          ok, so if dim bulb tester doesn't stay bright thats good, I would try it without the dbt.
                            Ok the backlight is working. But I maybe messed something up. I did accidentally make small crack in a corner Chalk it up as a learning experience.
                              Damn, sorry to hear that, they are easy to break.
