Following on from replacing fuse i thought i should check for shorts before powering on and luckily i did.
https://www.badcaps.net/forum/showthread.php?t=88016
The A04435 Mosfet is shorted all over. Removed from board and short has gone and out circuit is testing short
The capacitor above (C786) is shorting to ground both sides, removed and is good out off circuit
The pads are shorting with each other.. Followed the 8 vias to other side and dont appear too be going anywhere.
Is that cap supposed to have continuity or the pads?
