Bios For Lenovo All In One C20-00.(LA-C671P)
    Re: Bios For Lenovo All In One C20-00.(LA-C671P)
    Try this one from lenovo. Backup your bios first !
      Trying to This Bios.No Display ON It.
      Orignal Bios Have Bios Password...That The Reason We Want Bios
        You didn`t say it had a password. Remove the CMOS battery, power it on without battery, then shutdown and put CMOS battery back in. If that doesn`t clear it look for CLR CMOS CLR PWD jumper on motherboard, or 2 small triangles
          Yes Sir, There Is No CLR PWD/CMOS Jumper OR 2 Small Triangle. I Am Trying To Remove C-MOS/Power IT Without Battery/Shut Down And Put C-MOS Cell. But Same Issue Remain.
          Please Provide Me Good Bios As You Possible.
          Thanks For Giving Reply.
            backup your bios and upload it here .
              i need .bin for LA-C671P and the version 2006 please help mee...
              I have not tried the file that came up .. this serves me ??
                hello i check all version of la-c671p of this forum and nothig work for me, i check version of vinafix bin, and ec no work, but the original work, but no show display, any have the bin and ec please.
                  Try these , untested . If they don`t work check the Realtek RTD2136N IC
                    thanks you it works
                      thanks the first one worked in my all in one. did not check the second file. Thanks again
                        Lenovo All In One C20-00.(LA-C671P) ec bios
                          Hi, can someone tell me how to recover the bios? I downloaded the bin files but dont now how to restore it, my c20-00 died after a bios update, the update didnt fail but there is no video. Thanks
                            You will need an SPI bios programmer such as an EZP2019,CH341A,TL866II
                              Thank you very much, got the programmer and the 1.8v adapter and the first bin file worked
                                One question, is your Bios chip the w25x10cl? If it is that I need the 1.8v adapter to program ???
                                  Originally posted by ravenmx View Post
                                  thanks you it works
                                  How did you bro to program, I already have the programmer, I only need the .bin, do I need a 1.8 v adapter? The Bios chip is w25x10cl, the same does not give me video
                                    this file dosent work
                                      can we extract bin from exe file. if yes which tool to use.
                                        in this case you don't need a program ... right click on exe. and extract the file ... in the folder made, you have the bios ...
