Acer Nitro V motherboard caps and fuse required
    Hello all..
    Hoping someone can assist.
    I need to replace 3 capacitors and fuse on my motherboard but can not find where to source these.
    I have pretty much exhausted all possible avenues in Australia i.e Jaycar, Isas, leading edge, even an Acer authorized parts reseller.
    Looks like I need to source from abroad.
    The laptop is an Aspire Acer V Nitro
    Motherboard: Uranus_KLS 16858-1
    Laptop model VN7-593G_-73CP
    Parts required are:
    Capacitor C5502, SC4D7U25V5KX-L2-GP
    Capacitor C5503, SC1KP50V2KX-L-1-GP
    Capacitor C5504, SCD1U50V3KX-L-GP
    Fuse F5501, POLYSW-1D1A24V-GP-U
    The above components are identified from area of schematic as shown attached:
    Hope someone can point me in right direction
    Cheers
    Tuscados
    Re: Acer Nitro V motherboard caps and fuse required
    u can get them on digikey ofcourse.
    c5502 sc 4 dot 7 u 25volt 5kx 5kx maybe tollerance, but package ? 4.7uf 25 volt
    c5503 1000pf 50 volt 2kx
    c5504 .1uf 50volt 3kx
    fuse 1.1 A 24 volt
      fuse 1.1 A 24 volt
      Thank you, I will have a look
      Much appreciated
        Contacted Digikey they couldnt help me with the info I gave them.
        Thought about sourcing from older u/s motherboards but so many out there and schematics hard to source.
        Does anyone have any other ideas?
        cheers
          cheers
          What info did you give them ? All you need is 3 parts, you don`t need to buy them according to the long part number.The only thing to get right is the package size,are they 0402 or larger ? Have a look on aliexpress for capacitor kits
          4.7uf 25V
          1000pf 50V
          0.1uf 50V
            Hi I gave them all the info in first post.
            They replied "Sorry but the picture and the given data do not show us exactly the technical parameters of the parts.
            The SC4D7U25V5KX-L2-GP does not yield to any clear info what sort of cap it is, what capacity and voltage and so on.
            Parts remain essential un identified."
            Ok I will have a look for capacitor kits
              If you Aliexpress, avoid "Jintaoyu Store"
              After ordering capacitors on Tue 20-Oct, was checking daily to see if they'd been shipped
              Then on Fri 23-Oct, with no communication from them, status was "No Shipment" and "Closed"
              From Aliexpress "Eva":
              Originally posted by Aliexpress
              The order was closed because the seller failed to ship goods in time. I feel so sorry
              The refund will be processed in 3-20 business days. Please kindly wait.
              So Aliexpress get an interest-free loan for a fortnight minimum
              And I've now done what I should have originally, ordered from RS Components
              A bit more expensive, but I expect to get non-counterfeit capacitors within a couple of days, instead of a couple of months
                Just a question before I try to order capacitors.
                The repair shop i used couldnt give me back the capacitors they took off, so I had to measure the soldering area on the board to try and get the correct size capacitor.
                Am i correct to assume the larger the soldering area on the board the larger the capacitor?
                The reason I ask this is only one of the capacitors is identified on the board.
                So assuming the larger 4.7uF goes on the larger solder area on the board the capacitor size would be 2.0x1.2mm (package 2012) solder area 2.5x1.5mm
                0.1uF capacitor size 1.6x0.8mm (package 1608) solder area 2.0 x 1.0mm
                1000pF capacitor size 1.0x0.5mm (package 1005) solder area 1.2 x 0.5mm
                The above is so I can get the correct package size,
                Is my assumption correct?
                Cheers
                  c5503 is 0402 package
                  c5504 is 0603
                  c5502 is 0805
                  for my opinion
                    ok thanks for that.
                    On my first post..
                    Can someone tell me what the purpose is for these three capacitors and whether I can run the laptop without them
                    Cheers
