LG 43UK6200PLA - yellowish picture
    Re: LG 43UK6200PLA - yellowish picture
    Originally posted by tomislav4545 View Post
    When I did the half screen test it did flicker on the faulty side. Energy saving was on and when I switched it off it only brightened the screen a bit and nothing else. It was tested without any cables just power.
    So the other side did not flicker at all, just the "faulty side"?
      some more there, try #2, see what you get: https://smarthomeowl.com/lg-tv-screen-flickering/
        another tape "solution", which most of them are: https://www.youtube.com/watch?v=3bApo5i9yv0
          The other side didn't flicker. I will probably leave it as is for now. When I block pins similarly to videos you shared (10-12 pins at once) the picture would be solid but discolored.
            it is strange, I believe this is the only tape fix I have seen on here, where the tv was left flickering.
              There is probably more to the solution than what I did. I'm going to leave it as is and maybe in the future try again.
                well at least its watchable now,
                  I have an 86” tv of this “uk” series with similar problem.
                  If I cover pins 13-15 I get a perfect picture with no flicker at all but lose color. (Magenta) specifically.
                  If I didn’t cover pin 15 the screen flickers as you mentioned. From what I can tell there is never a perfect picture when using the tape method, One way or another the picture gets degraded somehow
