Dell Latitude 5590 model p60f LA-F411P BIOS
    I NEED BIOS
    Dell Latitude 5590
    model p60f
    DDM80 LA-F411P
    REV 2.0
    Re: Dell Latitude 5590 model p60f LA-F411P BIOS
    Bios extracted from dell exe file.
    test and report
      thank you but not work
        Post your original bios dump
          Thank you
          i found bios work
              I NEED BIOS
              Dell Latitude 5590
              model p60f
              DDM80 LA-F411P
              REV 3.0
              The above is not working
                Originally posted by hadi123456 View Post
                I NEED BIOS
                Dell Latitude 5590
                model p60f
                DDM80 LA-F411P
                REV 3.0
                post the backup of the bios
                  hi everybody i need bios for FDX40 LA-J261P Rev: 1.0 (A00) it's dell latitude 7310
                    Offtopic, start your own thread
                      i need the ec dump ddm80 la-f411p rev:3.0
                        plz help me
                          post the backup folder of the original main and Ec bios of the laptop.
                            hi i need 5590 rev:1.0 bios
                              post your old dump
                                Dell Latitude 5590 P60F002 bios req
                                Hi there, i request for Dell Latitude 5590 (P60F002)
                                Motherboard; DDM80 LA-F411P REV 1.0 (A00)
                                i tried bios from here but its other version
                                Before = no screen and fan spinning only when press off
                                with bios from here i get blinking code after 20 sec. 3 times white and 1 orange led
                                I also replaced pu610 driver ic becuse it was burned, cpu vcore is back
                                Its a i7 cpu and no grahics chip
                                Here is the old dump;
                                  Re: Dell Latitude 5590 P60F002 bios req
                                  Find attached two files to test, first one is your edited dump with cleaned ME firmware (same version as in your dump), the second is entirely rebuild one with stock bios version 1.1.9 (again same version as in your factory dump). If everything is ok with the hardware, machine should boot, if not your problem is not bios related.
                                  Good luck.
                                  Become a Badcaps supporter
                                  Thanks to all supporters.​
                                    Hi Vesko356, thanks for that, i tried both files
                                    the blinking led disappeared, but still no screen
                                    it draws 23 watts on my watt meter, and after 5 seconds it just drops to 15 watts,
                                    vcore goes from 0.88volt to zero. It looks like it goes to standby or something
                                    i tried heating up the cpu and replaced the other vcore ic. but still nothing
                                    didn`t foubd a schematic so it think the laptop is garbage now
                                      Yep, most likely it's a hardware fault.
                                        Dell e5590
                                        la-f411p rev 2.0 clean bios ok
                                        • moh17
                                          moh17 commented
                                          Editing a comment
                                          Excellent work .
                                          he is working well
