bios for HP EliteBook x360 1030 G2
    Re: bios for HP EliteBook x360 1030 G2
    Originally posted by Bfun View Post
    Ok, thanks,
    but my rcUnlocker is missing.
    Or can I download it?
    https://www.badcaps.net/forum/showthread.php?t=103526
      Ok, thanks SMDFlea.
      When I drag my dump file into RCUnlock, I get the following message: Wrong chip. Try reading and unlocking 16 MB chip !
      What is the Problem ?
        Ok, thanks SMDFlea.
        The 64mb chip is for the 8MB bios (8 X 8 = 64) and the 128mb chip is for the 16MB bios (8 X 16 = 128)
        Drag the 16MB backup onto RCUnlocker and see what happens
          My backup file is the 16Mb and I still get the previous message.
          flash w25q128 winbond.
            Try it now with the attached bios,you will still need to unlock it using RCUnlocker.The problem was you backed up as an OTP chip,it means One Time Programmable,that adds code to the end making it longer than the 16,384KB standard size that RCUnlocker expects to see
              ok thanks.
              I have a new RCUnlocker error, see below.
                I found the problem, RCUnlocker, did not have permission to write the modified file. Everything is OK and my backup file is patched.
                Thanks to you SMDFlea.
                I will try the patched bios tomorrow.
                  can you fix my bios? , i hv no display, fan spining.
                    try..
                      Originally posted by peste View Post
                      try..
                      not working still no display
                        flash it reply me
                          sir can you help me to unlock bios admin?
                            use the RCUnlocker tool and unlock it yourself
                              ok. thanks sir
                                Hi Guys,
                                Can anyone UNLOCK OR CLEAR BIOS password on this bin file. Backup which I took from main BIOS CHIP.
                                Thanks in advance
                                  Originally posted by mohamed ezzat View Post
                                  Hi Guys,
                                  Thanks in advance
                                  read post #156..
                                    black screen and f10 blink turn on after 20 sec turn off this is my bios file for 25q128
                                      Try and let me know if it works fine.
                                      all donations are welcome,
                                        hardware1
                                        laptop com on fan speed normal and 3 long beeps 2 short beeps
                                          hardware1
                                          Try to clean ram slot, put the ram in the other slot and change your ram.
