car cigarette lighter to car cigarette lighter jumper cable with a twist
    I had bought this device many years ago and never really used it much because I never had batteries that were good enough to use this device on because it draw up to 10 amps and would drain a battery very quickly so I have made a battery pack for this device now ( and for inverter that I also have ) but I still have to buy a 10 amp circuit breaker for it for it be completely safe to use it
    The reason why this device end up in a Radio Shack power supply case was the transistor small heat sink would get very hot to touch after a very short time and I had these power supply that I bought when they were being closed out and had a newer version of it which I did not think much of so I bought as many as I could back then I still use one of and to power small devices every so often
    This device did get recapped because it had been in storage for a very long time and because it had non brand name capacitors on it
    The output is 16.75 volts with no load on it and with a one amp it still maintains a 16.75 voltage ( incandescent light bulb load interesting results ) I put this device on a 12 volt li-ion battery pack that was discharged 9.75 volts but could not keep it working because I only have a 2.5 amp circuit breaker on it right now it was showing over 6 amp going to the battery pack
    After I do some testing I might end up putting a 12 volt temperature controlled cooling fan over the heat sink to cool it
    I will post some pictures of this when the project is completely done and I have done some testing on it when I can post the results
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
    Re: car cigarette lighter to car cigarette lighter jumper cable with a twist
    Well it turn out that the ones that I bought that were close outs the transformers are bad so they are going to be repurposed for some other projects that I have in mind that I do not have the time for right now
    9 PC LCD Monitor
    1 Dell Mother Board
        But I still have one that was brand new in a box that works good and the one that I use to charge nicad battery packs the current range was 400 milliamperes to 1.2 amp max at 24 volts
        I have three of them that the transformers are shorted out on the secondary winding I checked it with a ring tester ( but they were not new in a box these were bought at Radio Shack surplus outlet center back in the day )
        But I going to use one of them on a switching power supply to get a stable 13.8 volt output at least that is the plan anyway
        I have two ten amp version of same 13.8 volts one of I already took out the transformer and controller board
        The other one is still complete the way it was brand new and I also have one extra controller board for this power supply
        The one that I have taken out the transformer and controller board is going to possibly have a battery pack and small charger for the batteries I am tossing this idea around
        9 PC LCD Monitor
        1 Dell Mother Board
          Originally posted by eccerr0r View Post
          What are you confused about
          9 PC LCD Monitor
          1 Dell Mother Board
            i cant see any transformers, just a couple of inductors.
            it's a boost convertor right?
              Yes I was referring to the fact that I have several Radio Shack power supply enclosure that have issues and might make another boost converter for the same type of project
              9 PC LCD Monitor
              1 Dell Mother Board
                Well this project is done for the boost converter for jumping a car battery
                I replace the 2.5 circuit breaker for a 7 amp circuit breaker and now it does not trip out
                I ran it for about 5 minutes and the heat sink got warm and transistor got real hot but not hot enough that I could not keep my finger on
                To test this device I use a 18650 12 volt battery pack that was discharged to 9.35 volts and it got a little bit over 10 volts while charging it a 6.78 amps yeah I know that this is a little bit high but it has 9 battery cells in parallel so I was not to concerned about it because it has so many batteries in parallel and I was only doing for a short time
                Now I have have to build the 18650 battery pack for this project to be completely done
                9 PC LCD Monitor
                1 Dell Mother Board
                  I need to make myself a battery powered battery charger...
                    One note on the testing that I did above I use my car cigarette lighter socket for the power supply power
                    I cam going to use 30 amp boost converter at least that what it claims to do I am going to order two of them and see if can get the same exact results
                    I will post the results after I get them and do some testing
                    9 PC LCD Monitor
                    1 Dell Mother Board
                      But this one will be hooked up directly to the battery not the cigarette lighter and only because if it truly can put out 30 amp continuously this might be a problem trying to use the cigarette lighter outlet
                      9 PC LCD Monitor
                      1 Dell Mother Board
                        Well the boost converter came today and it set to 54 volt output with a 12 volts input ( by default )
                        But it going to get recapped before I put it in service because it non brand capacitors on it
                        Ones I have bought the capacitors for it I will post some pictures of this boost converter recapped and how I hook it up
                        I do not have 100 volt at 470uf capacitors on hand
                        I do not have 63 volt at 470uf capacitors on hand
                        9 PC LCD Monitor
                        1 Dell Mother Board
                          To pay $2.50 per capacitor is a little bit high for me really
                          Dig key parts order for these capacitors for this boost converter
                          565-4879-ND‎
                          ‎EKYA630ELL471MK25S‎
                          CAP ALUM 470UF 20% 63V RADIAL
                          Immediate
                          10 @ 1.25200 = $12.52
                          ‎565-4147-ND‎
                          ‎EKZN101ELL471MLN3S‎
                          CAP ALUM 470UF 20% 100V RADIAL
                          Immediate
                          10 @ 2.61200 = $26.12. ( over $2.50 per capacitor plus the tariff really )
                          Tariff: $1.25
                          Payment Method
                          Subtotal: $38.64
                          Shipping: $6.99 ( FedEx Ground ) I am not in a hurry for them or I would have used USPS priority mail for faster shipping
                          Sales Tax: $2.99
                          Total: $49.87
                          One note I have not used either series before ( I have used the KY before but not the KYA before ) ( I have used the KZE but not the KZN before ) these seem to be new I hope these will work because there was no real other options in this brand name that I could really use for this device ( there were only 5 options two of them were surface mount type capacitors )
                          One other note USPS priority mail shipping cost have gone up to over $11.00 really it used to be a little over $6.00
                          9 PC LCD Monitor
                          1 Dell Mother Board
                            Well here is an update for this boost converter that I am taking about above I powered on today and had the voltage up to 99 volts with no load the output capacitors are only rated 100 volts of course I not going to run it at that voltage I am only using it up to 18.25 volts to jump a very low car battery to over 12 volts for a car to start after the boost converter on it for 10 minutes if it is not severely low on charge
                            Now it time to mount it in a Radio Shack power supply enclosure yes I am repurposing a device that has failed for another purpose but this is for another day
                            9 PC LCD Monitor
                            1 Dell Mother Board
                              I have not had the time to do this project but have not forgot about it
                              9 PC LCD Monitor
                              1 Dell Mother Board
