Xbox classic/original 10v 3300uf Polymer replacement?
    For polymodding an original Xbox i'm looking for polymer replacements of the following capacitor:
    2x 10v 3300uf Nichicon PW
    One is on the left side of the board, the other one on the right as you can see the picture i linked below (the two big brown caps).
    Could i just use 2200uf polymers to replace them or do i really need the capacitance?
    I have searched the forum already but could not find an answer for it.
    Thanks.
    Re: Xbox classic/original 10v 3300uf Polymer replacement?
    use 5x 1500uf polymers and fill the 2 unused spaces.
    the pcb was designed for 5x 1500uf or 1800uf caps
      I think you are talking about the black HM caps closer to the heatsink? That's exactly what i already did.
      But my question was about the brown ones in the bottom left, and bottom right corner that i can't replace with 5 caps.. since i don't think this is for the CPU i'm not sure i could use 2200uf polymer replacements
        my moded 1.0 board
        https://www.badcaps.net/forum/attach...0&d=1564406932
          That 1.0 board seems to have a different layout. I've got the one i posted in the picture above and i can't fit 5 caps as you can see . Guess ill just use the 2200uf polymers and see if it works, or not .
            it should be good with 2200's
