Lenovo ideapad U330 not charge DA0LZ5MB8D0
    I have a problem, the laptop only turns on on the battery, it shows in the system that it is charging, but the battery percentages are dropping. (does not charge the battery).
    On the power supply itself, it does not turn on. New original power supply without changes.
    Lenovo ideapad U330T DA0LZ5MB8D0 REV D
    Re: Lenovo ideapad U330 not charge DA0LZ5MB8D0
    So without battery it doesn't work check your first and second mosfet for short.
      After desoldering two PQ20 PQ21 (TPCC8067) mosfets
      PQ20 TPCC8067
      D+S= 2,5ohms
      D+G= 120omhs
      S+G= 120ohms
      PQ21 TPCC8067 After setting the meter to 200 Kilo-ohms, no transition in any direction
      PQ21 looks compact and PQ21 no transition
        PQ20 TPCC8067
        D+S= 2,5ohms
        D+G= 120omhs
        S+G= 120ohms
        diagram in the attachment
          PQ20 TPCC8067
          D+S= 2,5ohms
          D+G= 120omhs
          S+G= 120ohms
          PQ20 measurement are of mosfet or PCB Traces after removal?? If the measurementsare of mosfet, replace it as its bad.
            After replacing it with a new PQ20 PQ21, the laptop works fine. Thank you for your help
              Gentlemen, after two days the same problem again. The laptop does not charge and does not turn on on the power supply itself. On battery, it turns on. I replaced the PQ20 again PQ21 (TPCC8067) Works fine. Why did the PQ20 PQ21 get damaged again? What else can I check?
              Original charger.
                Is the mosfet back defect then you must replace the charger ic also that controls the gate of the mosfet.
                  Ok, I'll test it on a new original charger
