Old 08-12-2020, 02:05 PM   #1
ay_erdi
City & State: istanbul
My Country: turkey
Line Voltage: 220VAC 50Hz
Default Beko B46-LEG-6B NO View Fault
Hi friends;
TV's image completely gone.
My transactions;
https://yadi.sk/d/3fJq7VnlbL7mqA?w=1
both of led bars have been replaced.
I played flex on cof board (cof board>>tv display 6 quantity).The fault is not fixed.
I disabled it in turn;T-con >cof board between flex fault is not fixed.
Image is still distorted.
I have read;power board(DPS-214-CP)ON CN3 socket all Voltage.
I have read T-con board voltage.
Could you help me;please.
ay_erdi is offline   Reply With Quote
Old 08-30-2020, 02:40 PM   #2
ay_erdi
My Country: turkey
Default Re: Beko B46-LEG-6B NO View Fault
hi guys;
will nobody help me ?
Old 08-31-2020, 03:03 PM   #3
dick_barton
dick_barton's Avatar
City & State: Cardiff
My Country: Wales
Line Voltage: 230V AC, 50Hz
I'm a: Hobbyist Tech
Can you post your pictures of the circuit boards on this Forum and also what voltage checks have you done and what were they?
dick_barton is offline   Reply With Quote
Old 09-01-2020, 03:53 PM   #4
ay_erdi
My Country: turkey
pictures;
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 09-01-2020, 03:55 PM   #5
ay_erdi
My Country: turkey
view fault
edit:add to photo
Old 09-03-2020, 09:26 AM   #6
dick_barton
My Country: Wales
That does not look good. If you remove one of the ribbons from the Tcon to the panel what is the picture like. Then reconnect the ribbon and remove the other ribbon to the panel and check the picture again.
Have you check all the voltages are correct on CN3 and CN4 of the power supply?
Old 09-05-2020, 12:13 PM   #7
ay_erdi
My Country: turkey
I removed ribbons one by one,#5 reply view ne changed.fault goes on.
I read on CN3 socket all voltages.CN4 socket no connected the cable ,this socket is empty
Badcaps.net Technical Forums © 2003 - 2022
