LG Flatron W2353V slight red hue and kind of dim.
    The screen has a red hue and is dim, when i try to boost the gamma and turn down the red in the monitor osd, then the blacks are more pale, and the screen has blue hue instead if red. Also even if the brightness is set at 100 in the osd, i can't get the screen to be to be brighter and the white to be white. I also tried to change the color profile and nothing. Can this be because of the capacitors in the power board or the light bulb, or just the lcd panel that is bad?
    Heres a video of a dim display fixed by chamging the caps in the power brick. So i don't know if this could be one of the problem.
    Here's a pic of my main led display on the left vs the lg w2353v side by side.
    Re: LG Flatron W2353V slight red hue and kind of dim.
    A reddening and dimming of the image suggests the tube/s are ageing.
