I have this board Macbook 2016 model on PP3V42_G3H line. Is the board dead or what ? Earlier it was around 1.8 and now it is 14 V instead of 3.4 volt on L7095 . Please advise.
Macbook Air 820-00165 A 14 V on PP3V42_G3H
Re: Macbook Air 820-00165 A 14 V on PP3V42_G3H
OMG. Probably toasted with such a high voltage but are you confident the reading is correct ?
Remove all power and check the voltage divider resistors @ R7095 & R7096. They must be the same value as shown in the circuits otherwise the downstream rail will get damaged.
These resistors define the 3v42 configuration.
Measure on the output of the inductor not the input.OpenBoardView — https://github.com/OpenBoardView/OpenBoardView
Can you confirm how you measured this rail ? The inductor has been recently damaged - after the measurement of 14v ??
The inductor (L7095) is not a critical component and can be replaced with any 2520 sized 10uh device. Often ferrite beads will work here but check their rated current before using. The rail itself is only 300mA but good idea to use 1A rated inductor or higher.
Perhaps you have a donor board or can borrow for testing ?
Then confirm the voltage rail @ L7095, pin # 2 as noted by @piernov.
In your repair, use lots of flux and watch how long the heat is applied onto the component if the heat setting is high. We use 550C on our clone Quick station (BEST Tools) but are cautious to not keep the heat on for too long on the component.
The inductor is a critical part of the buck converter, it cannot be replaced by a ferrite bead.OpenBoardView — https://github.com/OpenBoardView/OpenBoardView
The original inductor uses this kind of package. It is not the same thing as a ferrite bead used to filter high frequency noise though.OpenBoardView — https://github.com/OpenBoardView/OpenBoardView
