HP Elitebook 850 G6 BIOS UNLOCK
    Hello all,
    I've now got a HP 850 G6 that has a bios password.
    I've flashed the 256 chip, boots up "Bios update in progress" then password remains
    Removed and flashed the 128 Chip, says AMT disabling and reboots and password remains.
    I'm using the HPUnlocker tool.. ( I know it says unsupported, but Gave it a go as cannot get RC to work. )
    Do I need to flash them both at the same time and then boot? or am i using the wrong tool.
    Attached dumps.
    Re: HP Elitebook 850 G6 BIOS UNLOCK
    Try
      Originally posted by lapfix View Post
      Try
      Thanks Lap,
      I've been reading from Peste & Rehtorical that you need to program both the 16 and 32mb
        Sorted - Programmed 16MB with RCUnlocker.
          i need the 16 mb bios for HP EliteBook 850 G6 plz
            post your old dump
              empty by mistake
                plz need to unlock this bios
                  There must be the second bios chip, find it and upload the dump from it here.
                  Become a Badcaps supporter
                  Thanks to all supporters.
                    thanks for reply , this is it
                      Flash 16MB chip only, leave the 32MB chip as is.
                        thanks bro just fine
                            hello
                            I need to unlock this bios
                            thanks
                              Originally posted by newstory View Post
                              hello
                              thanks
                              Use 16MB file.
                              https://www.badcaps.net/forum/showth...ht=rc+unlocker
                                Originally posted by hoaca388 View Post
                                thanks work fine
                                  Re: HP BIOS unlock tool
                                  Hello!
                                  Elitebook 850G6 laptop BIOS password should be deleted from the attached BIOS. It would be great if someone could help. I tried with the HP Unlocker program, but it was unsuccessful. Your version may be older.
                                  Maybe there is an HPUnlocker available that handles this BIOS well?
                                  I appreciate any help.
                                  (Translated with Google Translate.)
                                  The previous compression failed. This is the good file:
                                  I must be doing something wrong:
                                  I type RCUnlocker.exe original.bin and it says "Wrong Chip! Try reading and unlocking 16MB Chip."
                                    Re: RCUnlocker
                                    Read your private messages,i moved your previous posts to another thread. There is another 16MB chip on the motherboard,thats the one that needs unlocking,hence the error message from RCUnlocker
                                      Re: RCUnlocker
                                      Thanks, that will be my first thing on Monday...
                                        I've got a 850 G6 which needs the BIOS password removing, when I open the laptop I am able to see the 256 chip which is labelled winbond 25Q256JVEN. I have been looking at threads on the forum and some people are saying this is the correct chip to flash. Is this correct or is there another on the other side of the board? Any pictures would be really helpful.
