Intimidation Professional sub advice please
    Hi all
    Far as i can tell this unit not producing any audio , although customer mentioned it does , but distorted .
    Anyway , started by testing impedance of main driver speaker .
    Measuring 80R , which i have not experienced before .
    Anyone familiar with this unit enough to know ?
    Can't seem to find any info on it .
    See picture of label on speaker .
    Re: Intimidation Professional sub advice please
    Most of the Blastking drivers seem to be 8Ω
      Thanks RJ for confirming .
      Will test with another driver & report back
        Tried one of my chunky 4 ohm speakers on this unit , but still no audio .
          Have a feeling there's an issue on the input board .
          Became suspicious when i noticed the LED for signal wasn't registering .
          Also cannot scope any audio on ribbon lead from input PCB to MAIN , although if i poke around on main , can measure an extremely low peak to peak audio signal.
            Some progress made on this unit .
            Discovered a low reading of 30R between pins 15 & 13 of U15 ( IRS2092S ) , compared to same measurement on other channel , which was over 4K .
            It's a drive chip for one of the channel output devices , which seemed to have survived .
            Surprised protection mode didn't kick in .
            Still not sure about the speaker impedance .
              There likely is no protection circuit. I suspect the output mosfets could also be bad, I see what looks like a lead trimming or solder splash on the mosfet lead in the lower left of your picture.
                Hi RJ , there is an LED on unit labelled protection .
                I did notice the solder splash also , but suspect that's during manufacture , as it doesn't seem unit has been opened before .
                  Pulled out the driver , which has a larger diameter than any pizza i have ever seen , 47 CM in fact .
                  Now impedance reading 1R2 therefore assume it has shorted turns .
                  I guess it should be a 4 ohm .
                  Not sure why the high reading before . Quite possibly meter probes not contacting fully .
                  Any suggestions for a replacement .
                    With the added cost of bass driver customer has decided against repairing .
                    Not having a particularly fruitful week .
