hp folio 9470m
    Re: hp folio 9470m
    ya, I think it is just dead too figured I would get something. musta messed it up somewhere.
      Re: hp folio 9470m
      Originally posted by imranromi View Post
      6050a2514101-mb folio 9470m
      working 100% ok check bios.
      TNX...it works....
        Re: hp folio 9470m
        THANK YOU.
          Re: hp folio 9470m
          This work..
            Re: Hp folio 9470m Working dump
            Working.
            ok, thanks
              Re: hp folio 9470m
              6050a2514101-MB-A03 / w25q128FVSG
              No reaction to power button.Charging led blinking white and orange when charger connected.
              After reading chip I`ve got information "chip is empty" so I used tested file FOLIA 9470M OK.zip from #6 and Elitebook Folio 9470M.zip from #72.After wtiting when I press Verify I`m getting an error "flash check error address:10h".Then when I`m reading it it says "chip is empty".I`m using ezp2019 which is detecting the chip model.I removed chip from mb, of course.
              I presume chip is faulty and I`m thinking to buy brand new one.Am I right or wrong?
                Re: hp folio 9470m
                I need diagram for
                folio 9470m
                  Re: hp folio 9470m
                  Originally posted by Udara Umayanga View Post
                  I need diagram for
                  folio 9470m
                  Schematic request go here.
                  Become a Badcaps supporter
                  Thanks to all supporters.​
                    Re: hp folio 9470m
                    Hi, is anyone able to unlock a dump file from an HP Elitebook Folio 9470m for me, I have tried using RCUnlocker but it gives me a python error something about a utf-8 codec can't decode a byte - while it still creates an unlocked file which does differ from the original programming it back into the flash chip the password has not been removed, I cannot get into the BIOS setup. Dump file attached.
                    Thanks!
                      Re: hp folio 9470m
                      thank you it is working
                        Re: hp folio 9470m
                        Folio 9470m-6050A2514101-MB-A03
                        TRY THIS IT WORKED FOR ME, ALSO COMES WITH SERIAL ...UNDER BIN FILES JUST SELECT ALL FILES TO VIEW THE FILE FROM PROGRAMMER
                          Re: hp folio 9470m
                          thanks working
                            Re: hp folio 9470m
                            I have couple 9470m's to unlock. The ones with w25q128xV BIOS chip, they have UEFI Bios With Win8 pro stickers. These I can read unlock and write back no issues. They are easily get unlocked. But the others they have mt25ql128ab BIOS chip, they have Win7 Pro stickers. Chips get detected. I can read them. Unlock them no problem. When I want to write them they fail at verification. What I am missing here ?? Any help greatly appreciated. I read the chips removed, I use ch341 programmer.
                              Re: hp folio 9470m
                              stop the verification and write one like this, see what happens
                                Re: hp folio 9470m
                                Goes well without verifying but the laptop, power light goes between white and orange. No boot, does not power on. I tried this on two laptops with same MICRON chips. In this (https://www.youtube.com/watch?v=96crJwtE1ls) video, the guy uses same chip, same controller and same programmer software with success. It is really annoying.
                                  Re: hp folio 9470m
                                  use one of these programs.
                                  https://www.badcaps.net/forum/showpo...6&postcount=10
                                  https://www.badcaps.net/forum/showpo...04&postcount=7
                                    Re: hp folio 9470m
                                    Tried ASProgrammer with a .bin file that I downloaded from this thread. It worked. But I dont want to flash all the laptops with same bios (or is it ok?) How can I make sure that my dump is ok? (dumping multiple times, I do)
                                    Two laptops that I tried was unlocked with RCLocker. Probably that is the culprit?
                                      Re: hp folio 9470m
                                      bios unlocked try it..
                                        Re: hp folio 9470m
                                        Thank you for this. File that I attached at #117 worked for me. But my question was is it ok to flash multiple BIOS with same file? Also which program did you use to unlock? RCUnlocker or HPunlocker ?
                                          Re: hp folio 9470m
                                          No. Every machine has unique data in it's factory bios, like the DMI data, also Intel ME firmware and so on. So the proper way to do it is to unlock the factory dump.
