Macoook Pro A1278 3 Beeps, Missing 1.5v rail voltage please help 820-3115-B..
    hi guys, this macbook it was working fine til i replaced the keyboard, after i put it back together it started beeping 3 times, and no video, it goes on endlessly.
    Schematic and boardview attached.
    C7332 is getting 12.5v, but nothing coming out of Q7330.. please help.
    Re: Macoook Pro A1278 3 Beeps, Missing 1.5v rail voltage please help 820-3115-B..
    3 beep means memory ram. remove and put one ram module at once.
      i did, multiple times, tried different memories even, but still beeping
        remove q7330 and report voltage on pin 1-2-3-4-5
          removed mosfet: pins 1-4 0volts, pin 5 has 12.5 V
          I've been tracing rails that produce 1.5v and notice that R2801 Has 3.3 on 1 side and 0 volts on the other side, it has the correct value which is 100k.
            u7300 voltages ?
              u7300 voltages ?
              pin 1-5= 0.0v
              pin 6= 1.8v
              pin 7= 0.0v
              pin 8 = 1.5v
              pin 9-10= 0.0v
              pin 11= 0.080v
              pin 12= 5.0v
              pin 13-14= 1.5v
              pin 15= 6.5
              pin 16-17= 3.3v
              pin 18= 0.70v
              pin 19= 0.0v
              pin 20=0.080v
                check if pin 4 and 5 of q7335 is shorted, if yes replace q7335
                if pin 4-5 no shorted replace u7300
                edit: voltage on l7330 without any ram module ?
                  Q7335 not shorted.
                  Measurement of u7300 where without ram.
                    ok then try to replace u7300
                      ok thanks friend i'll try to find another one of these bad boys.
                      is this chip responsible for creating 1.5v?
                      is it safe to make a jumper from pin 8 on u7300 to q7335?
                        wait: pin 4 of q7330 (after removed) has 0 volt, but pin 14 has 1.5 volt.... check c7325
                        if u can try this first before replacing u7300.
                        no dont do that jumper wire.
                        u7300 got enable signal from pin 16, but power good is not ok.
                        this chip create 1.5 volt for ram memory.
                        ps: pin 4 of q7330 has 0 volt after u removed it ?
                          C7325 is ok, not shorted.
                          Q7330 has 12.5v on pin 5, Pins 1-4 has 0v, whether is on or off the board.
                          I noticed resistor 2801 has 3.3v on 1 side and 0v on the other side, which is supposed to be 1.5v..Does this has anything to do with the memory not being recognized?
                            circuit about r2801 also generate ddrvtt_en that is present on pin 17 of q7330
                            edit: volt on R2810 both side.
                            is pch getting extremely hot ? if yes could also be a bad nb chip.
                              Nothing is getting overheated. R2810 has 3.3 on 1 side and 0.0v on the other side.
