Jump-starting a tablet...?
  • tmcw
    • Oct 2010
    • 382
    • Ireland
    I have an 8" Bush Windows tablet, and it stopped working one day. I'm looking into trying to either recover some data off it, or reviving completely with a new battery, if indeed that's what it needs.
    Anyway, when I plug in the charger (mini-USB type), the red LED light comes on as expected, but even if I leave it charging for a few hours, I still can't start the tablet, and the back of the tablet remains cold, whereas when it was working ok, the back would get hot, as would be expected.
    I understand a lot of these tablets need to have charge in the battery to run, they simply won't run off the power adapter, running power is constantly coming via the battery.
    The battery is connected to the mainboard with 3 different coloured wires red (P+), black (P-) and white (T). The connector actually has 5 wires, but the red and black are doubled, connected together at the battery board.
    The P+/red and P-/black are fairly easy to understand and connect to a supply, and I believe the T is for a thermistor, which might be harder to wire correctly without knowing what to do.
    So, I'm wondering if anyone has managed to do what I'm trying to do, using a bench power supply, how do I set it up, and how do I trick the system into thinking everything is ok regarding the thermistor/missing battery?
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Jump-starting a tablet...?
    have a look through sorins videos i had this issue on a hudl 2 where battery was only 3.6 volts, i removed battery connector used a cheap china lipo battery charger set at 2 amps charged battery too just under 4 volts using red and black wires re connected all works fine look at his hudl 2 video.
    https://www.youtube.com/channel/UCoo...Z0PFAPc4Ymg3RA
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • mkdj
      ASUS X571 no power : battery issue?
      by mkdj
      Mark and model: ASUS X571
      Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
      Tests already made:
      - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
      - I have removed...
      Today, 09:16 AM
    • techfreak9356
      Vostro 3400 (LA-K033P) won't charge battery, everything else ok
      by techfreak9356
      I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
      09-14-2023, 11:10 PM
      NVDC charger configuration...
      11-05-2024, 03:28 PM
    • ferah831208
      Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
      by ferah831208
      Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
      03-18-2025, 01:18 AM
