Sony MBX 247 Laptop Dead. Need help ( Pics attached )
  • IamPritesh
    • Aug 2017
    • 354
    • India
    Here I have this Sony laptop that is dead. Upon opening it saw SMD capacitor almost burnt . I did remove it and haven't replaced it yet. The board still not not start. I want to know is it essential to put a new one ? I have also flashed the bios chip with a new one and still nothing happens.
    Also from what I have observed.. the bios chip ( Pin8 ) has around 1 volt..
    The power button has around 1.5 volt..
    5 volt and 3 volt Always is present though.
    I have attached the two images .. 1 of the capacitor that was burnt and the other that produces the AC_OK signal and I want to learn how that works..
    ADAPTER SECTION of THE IMAGE
    PR187 has 19 V on one end and on the other end it is 0 volt. Is that normal ?
    BURNT CAPACITOR IMAGE
    PC 61 was burnt and short as well.
    Thanks everyone for your time.
  • Techtiger
    • Oct 2014
    • 1601
    • france
    Re: Sony MBX 247 Laptop Dead. Need help ( Pics attached )
    test Voltage on KU1 SIO IC pin 115 +3VPCU
    test Voltage on KU1 SIO IC pin 102 & 108
    test Voltage on PL13 out put +3VPCU
    • IamPritesh
      • Aug 2017
      • 354
      • India
      First of all thanks techtiger for helping me on this.
      The readings are as follows :
      KU1 SIO IC pin 115 +3VPCU = 3.3V
      KU1 SIO IC pin 102 = 3.3 V
      KU1 SIO IC pin 108 = Varies from 0.5 V to 1 Volt
      PL13 output has 3.3 Volt.
      Please guide me how to proceed.
      • IamPritesh
        • Aug 2017
        • 354
        • India
        Also I am not sure where exactly is the Power switch connector (CON1) getting the voltage . I checked the schematic but could not find it. I can see voltage source for capslock, scroll and numlock though.
        • Techtiger
          • Oct 2014
          • 1601
          • france
          power swith connect to CON1 pin 9 should be 3.3V NBSWON, remove the power button and test R107 for any short with multimeter after test pin 9 with out power button for voltage
          • Techtiger
            • Oct 2014
            • 1601
            • france
            for the PR187 it is normal for me PQ35 is a N-Channel Dual Fet when pin 5 goes high pin 3 goes GND
            • IamPritesh
              • Aug 2017
              • 354
              • India
              R107 has not shorting. The voltage is around 0.3 volt at R107
              KU2 Pin 4 and Pin8 have 3.3 volt.
              • Techtiger
                • Oct 2014
                • 1601
                • france
                test KU1 pin 108 with multimeter resertence with out power , did you test with out the power button ? test KU3 pin 7 & 8 for voltage
                • IamPritesh
                  • Aug 2017
                  • 354
                  • India
                  in post #1 you have mention that the BIOS is getting 1V so now the Bios have 3.3V, test KU1 pin 108 with multimeter resertence with out power , did you test with out the power button ?
                  BIOS (U3) is still showing 1 volt on pin8
                  KU2 has 3 .3 volt on Pin 4 and pin 8
                  I will test the pin 108 resistance asap.
                  • Techtiger
                    • Oct 2014
                    • 1601
                    • france
                    We are having a Confucian with the bios in your mob you have two Bios IC KU3 is your 1st Bios 2nd PCH U3 this IC gets Power after pressing the power button
                    • IamPritesh
                      • Aug 2017
                      • 354
                      • India
                      Sorry for the confusion.. KU3 location has no chip . Its empty.
                      Pin 108 of Io Chip resistance to ground is around 8K Ohms
                      using multi-meter.
                      Update : Just rechecked the schematics and it clearly says that KU3 is not mounted with an asterisk symbol.
                      • IamPritesh
                        • Aug 2017
                        • 354
                        • India
                        What should I do next ? Any suggestions will be appreciated.
                        • piernov
                          • Jan 2016
                          • 4435
                          • France
                          Did you replace PC61 yet? I guess it's required, it's part of a voltage multiplier that generates 15VPCU.
                          15VPCU is required to drive the gate of Q1, the MOSFET switching +3V_S3 from +3V_S5.
                          After replacing PC61, make sure PD27 and PD28 are not shorted, and that PC62/PC66/PC69 aren't either.
                          • IamPritesh
                            • Aug 2017
                            • 354
                            • India
                            Thanks piernov for you value able inputs. I am unable to find a replacement for 0.1U/25V cap. Does it need to be exactly the same capacitor ?
                            • Techtiger
                              • Oct 2014
                              • 1601
                              • france
                              piernov why is NBSWON getting 1V & the Bios Chip pin8 1V ?
                              • Techtiger
                                • Oct 2014
                                • 1601
                                • france
                                using multi-meter.
                                can you uplode PIC of that bios chip
                                • IamPritesh
                                  • Aug 2017
                                  • 354
                                  • India
                                  There is no chip on KU3
                                  Also does the capacitor need to be of the same value for pc61 ?
                                  • on/off
                                    • Oct 2016
                                    • 333
                                    • Indonesia
                                    • +3V_SPI come from +3V_S5 via R61 (short pad), When PQ44 ON require trigger from RVCCD (approx 12V).
                                    • S5_ON generated 15VPCU be RVCCD.
                                    • Maybe bios not working had effect KBC not work well.
                                    • Techtiger
                                      • Oct 2014
                                      • 1601
                                      • france
                                      thanks ON/OFF got the point
                                      • piernov
                                        • Jan 2016
                                        • 4435
                                        • France
                                        Oh yeah didn't even see it was required for +3V_S5… on/off is right.
                                        Yes capacitor should most likely be replaced with the same value. 0.1U/25V are pretty common though. Higher voltage rating will work as well but it'll not be easier to find a 50V rather than a 25V (and package may be too big).
                                        • thstuff
                                          Sony OLED XR-77A80J - Initially dead, now 4 Flashes
                                          by thstuff
                                          A) TV initially dead
                                          B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
                                          C) Was able to perform a Reset from Settings menu and completed out of box configuration.
                                          D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
                                          E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
                                          12-26-2024, 09:10 PM
                                        • bohaboha
                                          SONY KDL-46R473A ALMOST DEAD NO STB
                                          by bohaboha
                                          Hello to everyone in this wonderful forum.
                                          I have this SONY LCD TV KDL_46R473a
                                          PSU GL5 APS350 :1-888-122- 12
                                          MAINBOARD FY13_EU IP-012C101-4010
                                          black screen ,no STB no life almost death.
                                          on PS all the required volts are present 394V on the main cap and those on cold side 12.41V,3.45 and 3.45 are on
                                          Also 3,5,and 12v are on.
                                          nothing happens if i disconnect the PSU from the mainboard as on Samsung because here i think the mainboard gives the signal to the ps.
                                          don't know what to do next all suggestions and advice are very welcome​...
                                          04-24-2025, 04:40 PM
                                        • Talyn
                                          Sony 55W905 dead
                                          by Talyn
                                          My Sony W905 started to turn itself off an on every few minutes and blinking 8 times red in standby. A few minutes later the tv was completely dead.
                                          I can only hear the click of the PSU when attaching/detaching the power cable. No standby LED.
                                          Any advice? Thanks!
                                          04-15-2024, 08:14 AM
                                        • mrsith
                                          Sony KDL-55W755C - Dead
                                          by mrsith
                                          Hello again lifesavers.
                                          I have a KDL-55W755c that came in dead - not even standby light going on. Tested the power supply - all correct. Tested the output pins on the Led driver board (in which the power cord plugs in) - all seemed fine.
                                          I got a service manual for this model and tested the DC/DC converter by checking voltages on selected components. Every voltage was present where it should be. Service manual says that in this case a "Muffin" replacement is needed. This is the moment where I got stuck as I wasn't able to Google my way through it - till this day I...
                                          11-28-2022, 12:42 PM
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
