HP Elitebook Folio 1040 g3 Capslock/Numlock 5 blinks
    Hi everyone....
    please i need help; I have an HP Elitebook Folio 1040 g3 which was damaged by water.... I've replaced the 5VPCU regulator IC [Power IC] which shorted out due to the water damage.
    Now, it turns on, blinks the capslock/numlock light 5 times then restarts and repeats the blink process again and does that continuously.
    According to HP site, the 5 blinks is a System Board Failure.
    Who has any idea on how it can be fixed should PLEASE help out... No component on the board has labels, so it is hard to trace using Schematics
    [MOD EDIT] Link to schematic - https://www.badcaps.net/forum/troubl...-y0f-schematic
    Re: HP Elitebook Folio 1040 g3 Capslock/Numlock 5 blinks
    What are the missing voltage on the coils ? Is your +3/5/1.8VPCU are fine? Follow the page 67 power block & update what are the missing voltage
      Okay, thanks for the prompt reply, +3/5/1.8VPCU are okay...
      only 2 coils have missing voltages
        what is the PL number PL40 29
          It is not labelled on the board. Lemme try to trace it using the schematics
            Coils PL36 and PL38 have NO volts (0v).
            Which makes +VCC_GT absent
              check the Resistence to GND on PL38/36 , remove PL12 & power the MB to see if it's power up , check PQ16/17 check PU16/17 for any short & voltage of all pins PU16/17 ?
                Resistance to ground on PL36/38 = 4.6 ohms
                Without PL12, the problem is still the same, 5 blinks .....
                  No shorts found so far.......
                  PQ16/17 ....... okay
                  PU16
                  Pin 1 = 10.70 [Vin]
                  Pin 2 = 0v [GND]
                  Pin 3 = 1.3v [suspicious]
                  Pin 4 = 0v [NC]
                  Pin 5 = 5.12v
                  Pin 6 = 5.12v
                  Pin 7 = 5.12v
                  Pin 8 = 8.53v
                  Pin 9 = 3.53v
                  Pin 10 = 0v
                  Pin 11 = 2.43v
                  Pin 12 = 4.5v
                  PU24
                  Pin 13 = 0v [1V8A_PG]........
                    PU16
                    Pin 1 = 10.70 [Vin]
                    Pin 2 = 0v [GND]
                    Pin 4 = 0v [NC]
                    Pin 5 = 5.12v
                    Pin 6 = 5.12v
                    Pin 7 = 5.12v
                    Pin 8 = 8.53v
                    Pin 9 = 3.53v
                    Pin 10 = 0v
                    Pin 11 = 2.43v
                    Pin 12 = 4.5v
                    PU24
                    check DRVON on EN on PU22 than live is ok for me ! pin 2 is not GND PWM1_2ph so test again Ohms , PIN 6 is GND so check again
                      4.6ohms quite ok since it's CPU SOC , what is the voltage on PU21 pin 13 8 ? PU5 pin 8 ?
                        Those readings are for PU16. Pin 2 of PU16 is PGND while Pin 2 of PU17 is PWM1_2ph
                          PU17/18 Readings:
                          Pin 1 = 5.0v
                          Pin 2 = 2.0v
                          Pin 3 = 4.9v
                          Pin 4 = 5.12v
                          Pin 5 = 0v
                          Pin 6 = 0v
                          Pin 7 = 0v
                          Pin 8 = 0v
                            PU22 Readings:
                            Pin 1 = 5.89v
                            Pin 2 = 0.53v
                            Pin 3 = 4.9v [DRVON_EN]
                            Pin 4 = 5.12v
                            Pin 5 = 4.47v
                            Pin 6 = 0v
                            Pin 7 = 1.05v
                            Pin 8 = 1.50v
                              PU16
                              Pin 1 = 10.70 [Vin]
                              Pin 2 = 0v [GND]
                              Pin 4 = 0v [NC]
                              Pin 5 = 5.12v
                              Pin 6 = 5.12v
                              Pin 7 = 5.12v
                              Pin 8 = 8.53v
                              Pin 9 = 3.53v
                              Pin 10 = 0v
                              Pin 11 = 2.43v
                              Pin 12 = 4.5v
                              PU24
                              Yep PG is your problem how did miss it find out PR302 PR297 PR67 PR180 for any short or leak if ok remove PR302 & see if PG is coming back
                                PR302 & PR297 are short pads
                                PR67 = 2.58k ohms (3.3k ohms stated in schematics)
                                After removing PR302, PG is still 1.3v. But after comparing it with another working board (1040 g1), the 1.3v seems to be okay......
                                  what is the voltage on PG PU14 pin3 ? on your mob & 1040 G1 ? check what are rest PG missing
                                    PU14 Pin 3 [PG] = 3.06v [1040 g3]
                                    I haven't seen a schematic for 1040 g1. I want to try and search for a schematic of another motherboard using same power IC (3v_5v Regulator) as 1040 g1
                                      Thanks for your assistance so far
                                        For 1040 g1, Power IC is TPS51285A. PG [Pin 7] = 3.36v
