CORSAIR RM1000 - help needed!
    Got a Corsair RM1000 PSU that kicked off main fuses in the building, found the fault but cant identify the diode, see the pictures below:
    If anyone could provide me some schematics, would be thankful!
    Re: CORSAIR RM1000 - help needed!
    if he face has blown off, it's still in there somewhere - give it a good shake.
      There are no pieces, its been burned off I think.
        no, it split - i'm sure of it.
          Nowhere to be found, searched for an hour, whats the purpouse of this diode`? Why did it make such a power outtage in the whole building?
            no idea, you have to trace the tracks.
            it may be the pfc circuit.
              It is the PFC rectifier, and two power MOSFETs for the PFC boost stage are near this rectifier - one possible match for this rectifier could be an ST STTH8L06.
                if you get it running replace the secondary caps.i see crap.
                  It's c3d10060
                  DIODE SCHOT 600V 10A
                  Now I need som help from you.
                  On the bottomside of the main pcb.
                  Could you read off numbers\values on the following components:
                  R508
                  R507
                  R510
                  R511
                  R514
                  R509
                  These and F3NK80Z (q501) got blown\cooked in a water damage incident.
                  Any help appreciated
                    hey guys, i am new to badcaps.net and need your help on the rm1000 power supply unit. the power supply got fried and on opening it. i found a burnt capacitor and a varactor(not so sure, the component in front of the diode with reference to the picture) leaving the fuse ok. i changed the burnt components and visually everything seems ok. but its not powering up. i need your help asap. thanks.
                      start with making pictures and uploading it to this forum...
                        if i replace it..it will be ok..?
