hp folio 9470m
    Re: Bios needed for hp elitebook folio 9470m
    try and report
      Try this original
        Try
          Originally posted by pronto View Post
          Try
          i will try and let u know. thanks
            Originally posted by Claudiomfa View Post
            try and report
            thanks am going to give a trial.
              try and report
              cant be programmed error
                Explain the error... how cant be programmed? the file is your uploaded file but repaired
                  Originally posted by claudiomfa View Post
                  try and report
                  explain the error... How cant be programmed? The file is your uploaded file but repaired
                  i have been able to program but laptop no display
                    i got another working machine with the same motherboard then i make a copy of the bios chip.
                    My laptop is now working
                      Re: hp folio 9470m
                      tank's
                        HP Folio 9470m 6050A2514101-MB-A03 BIOS
                        Hello everyone. I have on the table HP Folio 9470m with mobo 6050A2514101-MB-A03. Laptop turns on and after few seconds blinking CAPS LOCK led by 5 times. After that the fan goes on max speed and there is no display anything. I need BIOS dump for this motherboard. Thank you.
                          Re: HP Folio 9470m 6050A2514101-MB-A03 BIOS
                          Here is the old dump.
                            Re: hp folio 9470m
                            Originally posted by imranromi View Post
                            6050a2514101-mb folio 9470m
                            working 100% ok check bios.
                            thank you so much that file is good imranromi
                              Re: hp folio 9470m
                              working %100
                                Re: hp folio 9470m
                                Big thx
                                  Re: hp folio 9470m
                                  Please i need this file for this motherboard ...someone please help me.
                                  6050A2514101-MB-AX1 bios bin file
                                    Re: hp folio 9470m
                                    Post the backup of the bios
                                      Re: hp folio 9470m
                                      please i need this file for this motherboard ...someone please help me.
                                      6050a2514101-mb-ax1 bios bin file
                                      100% working bios
                                        Re: Unable to Read BIOS Chip on Motherboard
                                        Hi can i get bios file for hp folio 9470m (winbond w25q128fv)
                                          use the one in item # 58 if you have the same motherboard, if not, post the motherboard model, and the backup of the original bios
