Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Tablets, and Mobile Devices > BIOS Requests ONLY!
Old 02-18-2022, 01:32 PM   #81
.::iRizwan::.
.::iRizwan::.'s Avatar
City & State: RWP
My Country: Pakistan
Line Voltage: Very High ;)
Lightbulb Re: Macbook M1 bypass FMM / EFI Unlock
Originally Posted by qava View Post
2nd NAND says
The hard drive is reversed, please re-insert the NAND...Attachment 256730
It's mean you are inserting the NAND in wrong direction.
.:: One Machine can do the work of 50 ordinary men , No Machine can do the work of 1 extraordinary man ::.
.::iRizwan::. is offline   Reply With Quote
Old 02-18-2022, 11:41 PM   #82
RethoricalCheese
City & State: Tartu
My Country: Estonia
Default Re: Macbook M1 bypass FMM / EFI Unlock
iPhone 12 nand says the same thing. JC just doesn't support iPhone 12 and up yet, including macbooks. Atleast that's my conclusion.
RethoricalCheese is online now   Reply With Quote
Old 02-21-2022, 02:51 AM   #83
Apple_Unlocking_Services
Banned
City & State: ����
My Country: United States
Line Voltage: 120VAC 60Hz
I'm a: Hardcore Geek
It’s A1706 intel MacBook.
Thats my video, its not A1706
look at the device keyboard on bottom left, you will see T2 mac keyboard 😁
Apple_Unlocking_Services is offline   Reply With Quote
Old 02-21-2022, 04:38 AM   #84
qava
City & State: Katowice
My Country: Poland
Line Voltage: 230VAC 60HZ
No, it mens this NAND is not supported. If I put NAND in wrong way than have information "replace chip 90 degrees"
btw I got a lot of knowledge in repair and i know how to recognize 1st leg of IC
qava is offline   Reply With Quote
Old 02-21-2022, 04:41 AM   #85
qava
My Country: Poland
Oh, looks like A1706, anyway, I wanted to clarify that this is not M1 Apple Silocon chip
Old 02-21-2022, 04:46 AM   #86
qava
My Country: Poland
Originally Posted by betonel View Post
One way for bypass M1 will be patching ipsw file, eg. UniversalMac_11.0.1_20B29_Restore.ipsw\022-10604-034\3_Apple_APFS
KRAActivationAuthViewController
Similar work has been successfully performed for iphone:
1. Download the iPSW file you need from the official website: IPSW.
2. Secondly, convert the iPSW file into a ZIP file by changing the extension and extract it.
3. Now open the extracted file folder, and you will see 3 different .dmg files in there.
4. Look for the biggest file and drag it to your desktop. You will notice that the .dmg files will not be able to open in one click. It’s because these files are encrypted.
5. You would need a firmware key to open this file. For this purpose, direct to “The iPhone WiKi” and find your firmware key.
6. Once you have the key, it’s time to use ???iDecrypt that is already on your Mac. Simply launch the software and open your .dmg file with it.
7. You will see a warning message on your screen. Simply click on the “OK” button and select your output folder and paste your key for “RootFilesystem."
8. Now, you need to click on “Decrypt DMG," and when the process is finished, you will see a success message.
9. Open the iPSW file that is decrypted and go to the Applications folder. Here, you need to delete the “Setup” file.
10. Then, exit this folder and right-click on your decrypted file and click on “Eject."
11. When the file is successfully saved, delete the original file and rename the new decrypted file matching the original file. Then, paste this file into the extracted folder again.
12. The last step is to compress the folder back to the IPSW format.
I also tried to try this but there's no firmware key so access to folder is locked. Step 5 kill all process
Old 02-21-2022, 11:33 AM   #87
kevingill
kevingill's Avatar
City & State: Lancs
My Country: England
I'm a: Hobbyist Tech
Don't know if this has been posted elsewhere, but on the activation screen where it asks for Apple ID/Password, I put in 'null' and 'null' and it says that the Apple account is locked and an email will be sent with instructions on how to unlock. It partly lists the email address.
Just thinking it might remind someone to look at the devices in their iCloud and remove the MacBook from their account? I can live in hope!
kevingill is offline   Reply With Quote
Old 02-21-2022, 12:56 PM   #88
Nico Latour
Banned
City & State: nice
My Country: france
they also can see your location! and macbooks in 90% lost modus
Nico Latour is offline   Reply With Quote
Old 02-23-2022, 03:06 PM   #89
techman9510
City & State: el cajon
My Country: usa
would we be able to remove iCloud lock if we took the SN from a locked M1 and put it in a T2 Mac bypass it using jailbreak than use jumpcloud.com to install MDM and use the MDM key to bypass the M1 Mac? we wouldn't need the wifi and bt address from the M1 because we aren't going though the activation process. has anyone given this a shot?
techman9510 is offline   Reply With Quote
Old 02-23-2022, 03:29 PM   #90
techman9510
My Country: usa
we can first attempt this on a iPhone and iPad. with mdm bypass key you would just put in key in the password field and leave the username/email blank. and it would be easier to attempt on a iPad because all we would need is the DCSD cable no Nand soldering required.
Old 02-24-2022, 04:43 AM   #91
betonel
betonel's Avatar
City & State: bucharest
My Country: romania
Line Voltage: 380V 50Hz
We've tried that.. it isn't working.. mdm key doesn't match. They send wifi mac + bt mac. Once u re able to change sn+wifi+bt you're good to go. No solution for that yet..
betonel is offline   Reply With Quote
Old 02-24-2022, 05:01 AM   #92
kevingill
kevingill's Avatar
City & State: Lancs
My Country: England
What happens if the Wi-Fi/BT chip has its power removed by cutting a track?
Or is it stored in flash?
Old 02-25-2022, 02:10 AM   #93
techman9510
My Country: usa
Can’t we get the wifi and bt address from terminal? I saw someone said they were able to open up terminal
Old 02-25-2022, 02:12 AM   #94
techman9510
My Country: usa
That doesn’t matter the problem is activation servers require SN wifi and Bluetooth to successfully activate the device. So we would need to get all 3 from a locked M1 and out it into a T2 Mac and than from their we can get the MDM key and theoretically use the MDM key to bypass activation lock on the M1 mac
Old 02-25-2022, 02:18 AM   #95
techman9510
My Country: usa
On iPads and iPhone I use a DCSD cable to read the hidden info from the NAND. Sn,wifi,bt etc etc I saw on AliExpress their is a DCSD cable that has a usb C connector I asked the seller what’s it’s for and he told me either for iPads or MacBooks. Maybe we can use this device to read the nand info on the MacBooks. Here is the link maybe someone can make a software for it.
https://www.ebay.com/itm/iDCSD-UART-...-127632-2357-0
Old 02-25-2022, 03:22 AM   #96
mazoot
Master of thoug
mazoot's Avatar
City & State: Chisinau
My Country: Moldova
Line Voltage: 220VAC 60hz
hoco u86 can make it possible?
Kill the state in yourself and you will be free like a wind...
mazoot is offline   Reply With Quote
Old 02-25-2022, 01:28 PM   #97
betonel
betonel's Avatar
My Country: romania
Interesting approach. Looks iDCSD is not exploiting anything, it's just a manufacturing testing interface, would be great if it can access NAND/shell for M1 device.
Old 02-25-2022, 01:52 PM   #98
techman9510
My Country: usa
I’m sure Apple uses special software that allows communication to the laptop and the software. So we would have to find our own exploit to make that communication possible.
Old 02-25-2022, 02:21 PM   #99
kevingill
kevingill's Avatar
City & State: Lancs
My Country: England
Has anyone actually tried the iDCSD cable with a MacBook M1?
Old 02-26-2022, 09:40 AM   #100
mazoot
Master of thoug
mazoot's Avatar
My Country: Moldova
i will find the adapter and test that
Badcaps.net Technical Forums © 2003 - 2022
