Power supply build quality pictorial DISCUSSION
This is a sticky topic.
    Re: Power supply build quality pictorial DISCUSSION
    ok whats the max power output this thing can handle?
    My Computer.
    AMD APU A4-3300 2.5ghz 1mb cache
    Motherboard GigaByte GA-A75M-S2V
    Kingston HyperX Blue DDR3 8GB (2x4GB)
    SB Audigy 2 ZS [B800] Sound Card
    500GB WD Caviar® Blue™
    1 Terabyte WD Caviar® Black™
    2 Terabyte WD Caviar® Black™
      We would need internal pics to really determine that. My guess is that it is good for 200W if it is a typical gutless wonder, 250W if it is not too bad on the inside (a decent input filter, not microsized secondary caps, the "35" sized transformer)
        if i open it that voids the warenty
        My Computer.
          Cant do much better here sorry.
          My Computer.
            Well, its got a non-existent transient filter, but the transformer looks decently sized, and the heatsinks look exactly like a seasonic 300W that I have.
            Those small caps are BH brand, looks like another one of logisys's OEM's.
              Will splode if i use it?
              My Computer.
                I've seen a logisys 575W run a 8800gts sli'd computer running cod4 on high settings just fine. But the 575W logisys actually has a complete input filter and a bridge rectifier.
                I can't really tell you if it will blow up if you use it without complete inside shots, but if you were to fix it up like I did to my 350W rosewill, then it might do ok for your setup
                  if i open it then i wont be able to take it back and i couldnt find any info online about or on hardwaresecrets.
                  My Computer.
                    how much was it?
                    If it was something like $50, I would take it back, as that is wayyyy too much for that. Your old dynex is much better built than it.
                      49 before GST and PST or HST
                      My Computer.
                        I don't know. I would return it and get a more reputable brand like corsair, antec, or even fsp. Or you could get the 400W delta that surfaces on ebay for cheap.
                        But it might actually be a decent psu, just we would need internal shots which would ruin your warranty.
                        This 400W delta:
                        http://cgi.ebay.com/New-Gateway-Delt...d=p3286.c0.m14
                        Has a pci-e connector, lots of sata connectors that each have their own little cover, but only a 4 pin cpu connector.
                        There is also a 550W AcBel power supply you can get for about $15, but it dosen't have pci-e. Someone here has a link to the website that you can buy it from.
                          I over paid for the Dynex too.
                          My Computer.
                            Goldenfield's upper end units are CWT. The lower end units like the S628 appear to be Huntkey.
                            This is the 410:
                            http://big5.thethirdmedia.com/g2b.as...3300c26p1.html
                            Huntkey is nearly always overrated by 100W. Some of theirs can be decent. Emphasis on the words "can be."
                              I guess new PCI-E video cards come with an adapter, so that shouldn't be a big issue.
                              My gaming PC:
                              AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                              ASUS M4A77TD AMD 770 AM3 Motherboard
                              PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                              G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                              TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                              WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                              ASUS Xonar DG 5.1 Channel PCI sound card
                              Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                              Antec Three Hundred Mid-Tower Case
                              Microsoft Windows 10 Pro 64-bit
                              Microsoft Windows 7 Ultimate SP1 64-bit
                                I dont use PCI e anyway.
                                My Computer.
                                  Is there a warranty sticker stuck between the lid and the main case of the power supply that has to be ripped to remove the lid?
                                  If there isn't, then if you want to take a risk just remove the screws carefully and take off the lid carefully, without damaging the finish on that power supply.
                                  If there is, don't open it.
                                  My gaming PC:
                                    This is the 410:
                                    So essentially, he probalby just bought another 400W dynex.
                                      At a slightly better price than the Dynex, along with what appears to be a nice black finish on its case.
                                      My gaming PC:
                                        Phaihn: just use the Dynex, it's not that bad of a power supply at all. Besides, I don't think your system will go over 200 watts even at full load.
                                          Theres 2 stickers on it one conectting 2 parts and the QC sticker thats cover one of the screws
                                          My Computer.
