#1 |
City & State: Perth Western Australia
![]() I have just received a used P4 and the vent hole in the top of the case is open allowing atmosphere into the case. I normally see this hole sealed. It occurs to me that if the hole is open then excess pressure based on high temperature has occurred and popped the vent.
I have Googled many different ways to get some enlightenment on this vent but have found nothing of use. Comment or input please.
Gigabyte EP45-DS3L Ultra Reliable (Power saver) Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12 160Gb WD SATAII Server grade Nvidia 8500GT 256Mb 160Gb WD eSATAII Server grade for backup. Samsung 18x DVD writer Pioneer 16x DVD writer + 6x Dual layer 33 way card reader Windows XP Pro SP3 Thermaltake Matrix case with 430W Silent Power 17" Benq FP737s LCD monitor HP Officejet Pro K5300 with refillable tanks |
#2 |
![]() It's merely a hole for letting out gases during curing the sealers during manufacturing.
Sounds like you never seen one with a open hole. Especially brand new CPUs. Don't worry. ![]() Cheers, Wizard |
#3 |
![]() Thanks. You right I have not seen this hole open before. All others are sealed. I would expect to be sealed whilst not installed to keep out ambient moisture.
So no suspicion of a cause. |
#4 |
#5 |
City & State: dayton ohio
My Country: U.S.A!
Line Voltage: 12vdc,120/240vac,480vac 3ph on my bench
![]() since the mobile varients dont even have the heat spreader and have the bare die exposed its nothing to worry about.
#6 | |
City & State: Eastern coast
My Country: Australia
Line Voltage: 240V 50Hz
I'm a: Hobbyist Tech
![]() Quote:
#7 |
![]() Thanks for all contributions. I have learned something AND the CPU passes all diagnostics.
#8 |
Deputy dood
City & State: Berwick, PA
Line Voltage: 120VAC 60HZ
I'm a: Hardcore Geek
![]() Indeed... without the hole, the airspace between the heatspreader and the CPU die would be air-tight. When the processor heated up, I would imagine it would break that seal one way or another, and it might not be the way you want it to
#9 |
![]() True if not mounted. But I would suspect that if mounted with heatsink compound the vent would be sealed.
#10 |
![]() Exactly, the copper heatspeader isn't totally sealed all around on later CPUs as part of improvement manufacturing process and cut down on cost of punching out tiny hole and less use on glue.
http://home.arcor.de/xxmartin/A64/a64_ihs.jpg this is also found on Core 2 Duo (using lipped heatspeader). http://www.techpowerup.com/articles/...cking/intel/37 (fails to view with FF, IE viewable. :P) Cheers, Wizard |
#11 |
Large Marge
City & State: Kalamazoo, MI
My Country: United States
Line Voltage: 0-120VAC 60Hz
![]() I just looked at it in firefox.
#12 |
![]() Thanks Wizard
Those links are a great contribution. Makes facts crystal clear. |
Thread Tools | |
Display Modes | |
