This is a sticky topic.
    Originally posted by Th3_uN1Qu3 View Post
    Is it the one with the green label? If so... i'd throw it away. It has a cheap fan that will wear out and no protection circuitry. Depending on your luck, it'll either fail gracefully due to capacitors gone bad, or it'll melt a trace and blow up everything connected to +5V and +3.3v.
    Not fun. Seen one where the 12v went open circuit, and 5v went to 8.3v, 3.3v to 7.5v. Needless to say the motherboard and the hard drives didn't make it.
    Both PSUs have their fans changed.My 450W PSU uses a Titan fan from a Socket 462 HSF,because the stock fan on it was on its last legs.
    On the 400W I made a mistake:the caps are not CapXon.They're Seacon.
    Otherwise,I'm real glad I scrapped the PCB in a Codegen 350W PSU.The case was handy for my Delux 400W PSU.Again,it sees just 2-3 hours of use which is a very light use.Also,most of the hardware it powers isn't consuming more than probably 100W.
    This PSU seems to still hold strong,even if the wires on the fan controller broke. (they were 2 wires,1 red 1 black,that were attached to a header on the PCB)Wasn't a big problem,I attached the fan to a 4 pin connector (not the square 12V one,the usual HDD/CDROM plug)and now it works the same as before.
    The 450W one has enough cooling to run fine.It runs since 2008,so it's pretty old.(6 years)
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
      Saw this on a Deepcool power supply review (an old CWT probably GPA design) :
      More pictures here: http://www.chinadiy.com.cn/html/15/n-12915-5.html
        Not a good look there at all, especially with the controller IC. It is CWT, though, so I'm not really surprised.
          Mean Well DRP-240-24
          1500uF 35V (x2) Chemi-Con KY on output with 47uF 63V Rubycon YXG after final filter chokes.
          220uF 450V Rubycon MXR primary unit.
          Four other electrolytics (100uF and below) are CapXon KM Series.
          IRFP460A PFC stage with HFA15TB60 PFC rectifier and 2SK2082 primary switcher, all protected with thermal overload switch.
          KBJ608G primary side rectifier with ESAD92-02 secondary side output rectifier.
          Fairchild ML4800CP PFC/PWM controller.
            They sure know what they are doing.
            I have seen pics of other meanwell PSU's that use CapXon capacitors, it seems they have a little addiction to them! :P
            Muh-soggy-knee
              Maybe they just can't afford better ones, but they Mean Well.
                Dynex DX-400WPS
                Huntkey "400W" Maybe peak, but I doubt continuously. Although, the fan runs at 100% all the time so it does run really cool. Main toroid seems small though.
                8A bridge, J13009's (TO-247), Jianghai 680uF 220V input caps, and they actually tested 680uF!! At least the 13009's get that beefy heatsink to themselves, although it'd be nice to see more fins on it instead of just a block of metal. Transformers look good...
                40A schottky on the 5V and 3.3V. 12V has two 20A schottky rectifiers, and the 12V wires are separated. I don't see OCP shunts, so does this mean that the OCP is just built into that SG6105?
                Recapped the thing, looks good now! Only one Fcon cap was out of spec, and it was the one before the coil on the 5V, and it was touching the main toroid
                  Not a bad unit. No, the SG6105 doesn't support OCP. That is a single rail unit.
                    I think I see a green thermal sensor in the fifth image. Are you sure the fan runs at +12V all the time?
                      Oh, I could have sworn it did. Doesn't bug me that it's a single rail unit. It could probably output 30A on the 12V if the switchers could handle it.
                      You're right, there is one down there, but the fan always runs really fast and loud, maybe the thermal fan control was just poorly implemented.
                        It supports OPP, but no OCP
                          Okay, that's what I was thinking of. I did notice though that the 12V wires for the CPU P4 connector measured 12.08V, and all the other 12V wires on 24 pin connector, molex, and Pci-e all read 12.18V
                            Could the fan be running out of lubricant if you didn't lube it already (if that's why it's loud, just a guess... does it spin for long after you cut power to it)?
                              Since it's Xinruilian, I checked it before I even recapped it. It was bone dry, so I oiled it. It spins well. It's not loud as in dying bearing, it's loud as in high RPM
                                Maybe the thermistor is for over temperature protection, not for fan controller
                                  We've had to throw out a bunch of old PC component at work. I saved this HIPRO psu. It was in an AST server that was just collecting dust in the past 15 years. It has plety of peripheral connectors. It's an epic overbuilt unit compared to simple AT psus. Has some extra circuitry for standby power and other signal outputs also.
                                  Funny that capacitors range from Rubycon to Teapo, Crown and Jamicon...
                                    In the final picture,why there are 2 P7 connectors?I see it's a AT PSU,but I don't really think a motherboard would require so much power.Also,300W and AT connectors,that's worth saving.BTW,what's that fan-style header for?I looked at picture 5 and it's connected to a board on the PSU,not to the fan itself.
                                    Main rig:
                                    Gigabyte B75M-D3H
                                    16GB DDR3-1600
                                    Delux MG760 case
                                      The third connector is an extra 5 volt supply to the mobo (which wasn't in the tower case for a long time so we don't know the exact model). That green-black-black-red was going to the mobo too. A micro remote switch could turn on the psu similar to an ATX ps_on-gnd short.
                                        That green "A" cap (the 2200uF one) looks ripe for blowing up.. doesn't appear to have a vent on the top!
                                        Muh-soggy-knee
                                          Awww, man! I want that green cap! That would be awesome in a fire with no vent stamp.
