Microsoft Surface Pro 3 UEFI password
    Re: Microsoft Surface Pro 3 UEFI password
    @ruzhda
    password = qualyar
      Originally posted by Maxpower3 View Post
      Open your dump with Hxd or other Hexadecimal program
      Locate area with
      texte AMITSESetup or Hex 41 4d 49 54 53 45 53 65 74 75 70.
      Take the hex values in the red area (two passwords can be stored).
      Put the hex values in excel decoder.
      I try this way, but can't find texte ''AMITSESetup''
      Maybe because i have Surface Book, but this manual for Surface Pro 3?
      I make dump file with Universal bios backup toolkit 2.0
        Could you guys help me find the uefi password ?
        Dump file attached.Thanks
        Brian
          Brian
          The password is:
          f1rew0rks
          Become a Badcaps supporter
          Thanks to all supporters.​
            Thank you Vesko356, the password is working ,where you can find the location AMITSESetup strings and length, if you can help me. Thanks for quick solve my problem.
            Brian
              Thank you Vesko356
              You're welcome.
              Brian
                Any help on the BIOS password would be great, could not find it myself.
                  Originally posted by taloncronis View Post
                  any help on the bios password would be great, could not find it myself.
                  1234
                    Originally posted by Vesko356 View Post
                    1234
                    worked like a charm, Thank you.
                        Hello
                        I have a problem with the BIOS password at my surface pro 3. I thought to remember the correct password, but it doesn't work. After a lot of reading and learning I created the dump and also found a password. By the way, it's the same I remember but this doesn't work. It seems that there is something between the 5 letters. Can someone help?
                          Originally posted by Skoda352 View Post
                          Hello
                          @Skoda352
                          Hash:
                          3693DF267FBA074DA6E022747D07D89A
                          332E8EC1E95444E89F7BFA0E55A2B035
                          0BC9665CC1EF1C83
                          Password: minka
                          m - mike ( lowercase )
                          i - india ( lowercase )
                          n - november ( lowercase )
                          k - kilo ( lowercase )
                          a - alpha ( lowercase )
                          In Laptop, type the password and press <Enter>.
                            @onizzbox
                            Thanks, I found that myself but it's not recognized as correct. "Password wrong" is the message. Any idea where the error is?
                              @onizzbox
                              @Skoda352
                              The keyboard is probably not coded to US standard. Use an external USB keyboard to enter the password.
                                @onizzbox
                                I have tried:
                                only touch, is qwerty so should be US
                                original microsft keyboard via connector, is qwertz so DE
                                usb keyboard also DE
                                All three attempts bring the same error. Will try to get a USB keyboard in english.
                                  @onizzbox
                                  I have tried:
                                  @Skoda352
                                  It is likely to work as the password is correct. However, if it doesn't work, you will need to rewrite the BIOS.
                                    Originally posted by onizzbox View Post
                                    @Skoda352
                                    @onizzbox
                                    So the ordered keyboard has arrived. Same error message "Invalid Password". Let's see if I get into the topic of rewriting bios or if it's getting too complicated for me. Anyways thanks for your help.
                                      Originally posted by AAAC View Post
                                      @Compaq23
                                      I have sent you a utility in a ZIP file that must be run as administrator, I've even included a TXT file with brief instructions. After you read the bios file you may upload it here.
                                      Hi, can you send me that too? Thanks.
                                        Hello everybody,
                                        I wanted to clean up my SP3 with a complete new installation of win10. The new installation failes all the time (remains at a completion of 84%). At the moment I'm not able to boot from a usb stick, because i dont know what the bios pw is.
                                        So there isn't a running windows on the sp3. Is there any way to get a dump of the BIOS?
                                          @taim
                                          The utility is in post #250:
                                          https://www.badcaps.net/forum/showpo...&postcount=250
