LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Originally posted by feherhollo View Post
    Lenovo T540P and W541 bios password.
    Have 2 bios chip. Which chip should I patch??
    The Auto-Patcher only works with the 4MB chip.
    I've already unlocked the Lenovo T440p with it.
    Good luck ...
      I have done today T470S and T460s. everything work flawlessly
      big thanks guys
        Good luck ...
        Thanks. Done!
          У меня Lenovo ThinkPad L470. Пожалуйста, удалите белый список из BIOS. Спасибо.
            Try ....
              Downloaded, unzipped, python installed, but after trying to run autopatch.cmd, it starts and closes straight away. What is causing this?
                Originally posted by markus1741 View Post
                try ....
                cleaned wwan (lte) ?
                  can anyone look on my original locked bios dump?
                  It is from locked t480...i have used patcher, then flashed back, but nothing - still power on pass or stuck on logo
                    Good day to all - I hope you're doing well.
                    This is my first post, so it might get a little winded. As a novice, to all things bios, this entire process seems a bit daunting,
                    but unperturbed "I endeavor to persevere".
                    Last year - from a recycle outlet - I received a couple of Lenovo laptops - T460s 20FA, and an X220 - with bios password.
                    I can use the X220 - which I am now - but not the T460s. Luckily I Googled, and found you fine folks. YAY!
                    Since then, I've been trolling this site - for a couple of months - with the exception of the holiday season - Happy New Year! -
                    trying to obtain as much knowledge as possible to remove the bios pswd, and to avoid asking questions,
                    that will most likely be ignored by all of you fine individuals.
                    Believing I had ascertained the requisite knowledge, I decided to scream JERONIMO!
                    My test laptop is the Lenovo X220, running Windows 7 Pro 32bit.
                    I have purchased - what I believe is the prerequisite hardware - a test Clip Board EEPROM BIOS Programmer CH341A.
                    1) I have downloaded and installed AsProgrammer_2.0.0a14; Colibri (not sure yet if needed); lenovo_autopatcher_0.2;
                    NeoProgrammer V2.2.0.8; Phyton 3.8 (not sure if it’s installed correctly); and UEFITool_0.28.0_win32.
                    2) I've also downloaded "Patched T460S ME_CLEAN", which I haven't done anything with as of yet.
                    3) I've extracted - 3 times without error - the original -as far as I know - bios image from a Winbond W25Q128FV bios chip on the T460s (20FA).
                    4) I have placed a copy of the original bios .bin - named "tp460sbios.bin" - in the lenovo_autopatcher folder, then pressed shift,
                    and using my mouse, right clicked on autopatch.cmd, but only a cmd window flashes on screen.
                    No additional output is produced – so my dilemma – I’m not sure how to procced next.
                    What I’ve been having difficulty finding, and I'd like - if you all would be so kind – is for someone to provide me with a link,
                    or tutorial that can help me accomplish the task at hand, without my interrupting – any further – the excellent work you're accomplishing – meant sincerely – without me asking inane questions – as if this post isn't already.
                    Much appreciated any, and all assistance, positive, and or negative.
                    Thanks,
                    deviouswun.
                    Moderator – if this post is misplaced, please place it where you see fit, or just let me know where you’ld like me to stick it.
                      This is my first post, so it might get a little winded....
                      ...put autopatcher + bin image into root of python folder
                        Wow! That was quick. I appreciate your illuminating reply
                          X1 carbon 7th gen need password removed, anyone help?
                            ...test it
                              ***SOLVED***
                              ...was needed to fill any pw
                                ...test it
                                Not working only beeping and no video
                                  ...you must wait...and maybe make some reboots.
                                  all batteries disconnected and pressed switch on mobo
                                    same problem
                                    can you help?
                                      Originally posted by rbnote View Post
                                      Hello everyone, I need a help with bios pass thinkpad L13
                                      i have same problem
                                      any solution?
                                        Is this the correct folder? Still not working for me...
                                          ...put all files from autopatcher folder into root of python folder, then drag and drop origbios.bin to autopatch.cmd
