CP1500EPFCLCD - failure
    I have a Cyberpower CP1500EPFCLCD which is failing on battery test (power cord detached). There are no errors on LCD screen, no issues reported on PowerPanel software. Not sure if this is linked or not but I suspect that this behavior came after a thunderstorm although the UPS was connected to another AVR.
    I have checked most of the components (no sign of burned components, capacitors looks good), mosfet checked, relays checked and working, batteries are ok but still not switching to invert the 24v DC to 220 AC.
    Any help or schematic (even better) is highly appreciated.
    Re: CP1500EPFCLCD - failure
    Shows some pictures of the front and back of the boards so we can see what you are dealing with
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
      I hope these pictures are ok.
      Thank you
        The first thing I would do is replace the viper ic chip right in front of transformer and the low UF capacitors that are near this chip
        I would also highly recommend that you use a incandescent light bulb instead of the fuse is just in case there is still something else wrong with this switching power supply
        9 PC LCD Monitor
        1 Dell Mother Board
          i take it you tested the fuses ?
            Hi, I have just replaced Viper and all UF capacitors. The battery is charging, fuses are all ok, but I cannot make the UPS to switch from line to battery (test, unplug). I'll try to use the "bulb" method to see if there is something else.
              all fuses are ok.
                I would check the devices that the battery terminals are attached to the heat sinks use a 1156 light bulb or a MR16 light bulb 50 watt one on the battery terminal while testing the battery circuit
                Google the part numbers that are those two parts are mounted on the heat sinks please post the part numbers and or post the pictures of them
                9 PC LCD Monitor
                1 Dell Mother Board
                  Hi, I got the point but since the batteries are providing 24v I'll check with something similar but at 24 v.
                    Sorry, I do not understand this part. You mean the light bulbs or the mosfets?
                      If they are mosfet on the heat sinks then you would want to test them to make sure that are working the incandescent light bulb is in series with the battery just in case something goes terrible wrong with the circuit
                      For the battery power not to power the inverter is what seems to be likely your problem now so you need to figure out is it the mosfets or is it what is controlling the mosfets is where the issue is
                      9 PC LCD Monitor
                      1 Dell Mother Board
                        Right. I have already checked all Mosfets and they are fine but I have decided to replace all of them and now I'm looking for what I consider being the controller: MC34063AL.
                          Did you ever find the solution? I am having the same issue where it will not switch to battery no matter what.
                            First I would checked is, what happend with current from battery, is drawn any current at all or some pulses... first use a DMM to see if it safe, and then device with needles, to see fast response, so you can trace.
                            Second check the enable pin state on chip ic invertor, is it ok. Is the voltage from batt present on mosfet, and the gate receive signal?
                            But maybe in this like scenario, for everything with uC, the manufacturer can programable the "feature" which sais: it is time to buy new, repair is too expensive, sad.
                              2015=Been around for a good while, but I don't consider it that old yet.
                              ASRock B550 PG Velocita
                              Ryzen 9 "Vermeer" 5900X
                              16 GB AData XPG Spectrix D41
                              eVGA Supernova G3 750W
                              Alienware AW3423DWF OLED
