Re: Dell W1700 LCD Rev00
That that high frequency whine is from the inverter.
Too low a frequency on the inverter probably (in the range of human hearing). Adjusting the brightness adjusted the pulses from the PWM and either reduced the whining frequency or reduced the vibrations from a loose winding on one of the inverter transformers.
Moniserv charges way too much for those inverters probably got them from China for 10 bucks.
I could buy a generic inverter and splice it in there for less than half the price but where's the fun in that .
The first thing to check with a blown fuse in any electronic circuit is for shorted semis. The inverter driver transistors should always be the first suspect with either a blown fuse or a backlights on for a second then off.
