I have a model 87 fluke multimeter with Q8 showing bad and I am looking to replace it. Fluke no longer stock it and don't have a substitute for it I can't see any markings on it so can't find a data sheet. Was wondering if someone could recommend a substitute from the schematic attached
Fluke 87 Meter repair
Re: Fluke 87 Meter repair
What happened to the meter that caused Q8 to go bad?--- begin sig file ---
--- end sig file ---
Originally posted by retiredcaps View PostWhat happened to the meter that caused Q8 to go bad?Last edited by davg; 08-05-2020, 06:26 PM.
Q8, Q10 are at the power system for the DMM IC, which is never supposed to see any overloads. It could happen if you were running the DMM from a bench power supply instead of the 9V battery and caused a ground fault. But this is uncommon.
I would say good chance the DMM IC is fried if those parts failed There's a bunch of parts to protect the DMM IC and why didn't they work?
You could leave out Q8, Q10, Q3 and jumper battery(-) to VSS at C21 just to see if the meter can boot up. If there is a short or overcurrent on the VDD/VSS I think the DMM IC has shorted.
