Troubleshooting a Asus X541UVK
    Hello everyone. Hope you're all doing great in this crazy world
    I am an IT person, but not much of an electronics guy (actually not at all), so I need your help with finding the cause that's stopping this laptop from powering on.
    Luckily I've found the boardview of this particular board on this forum, so this should make things a little bit easier for me (and hopefully for you deciding to give me a hand). I'm also attaching it here in case someone else is troubleshooting the same board in the future.
    First things first, I confirm that:
    1. Power adapter is OK
    2. DC IN is OK
    3. First 4 fuses are OK
    4. Mosfet is OK
    By OK, I mean 19V is present
    But then, there is a resistor (PR8938) which seems to be connected all over the board. At this stage I am not sure how I should resume troubleshooting. I tried to trace all linked components to this resistor, and 19V seems to be present everywhere.
    Don't want to misguide you, but visual inspection shows just a little bit of corrosion on capacitor C5564. There is no voltage going through, not the USB chip it's linked to (U5505).
    Re: Troubleshooting a Asus X541UVK
    what is the voltage on PQ8902 pin 4 & 3 after check PR8938 voltage ? PU8701 all pins
      Hey
      PQ8902 pin4 = 24V
      PQ8902 pin3 = 19V
      PR8938 = 19V
      PU8701 pin1 = 0V
      PU8701 pin2 = 0V
      PU8701 pin3 = 3V
      PU8701 pin4 = 0V
      PU8701 pin5 = 0V
      PU8701 pin6 = 3V
      PU8701 pin7 = 0V
      PU8701 pin8 = 0.8V
      PU8701 pin9 = 5V
      PU8701 pin10 = 0.8V
      PU8701 pin11 = 0V
      PU8701 pin12 = 19V
      PU8701 pin13 = 5V
      PU8701 pin14 = 0V
      PU8701 pin15 = 0V
      PU8701 pin16 = 0V
      PU8701 pin17 = 5V
      PU8701 pin18 = 0V
      PU8701 pin19 = 0V
      PU8701 pin20 = 0V
      This controller is extremely small, it's very difficult to check (I hope the measured voltages are correct).
        check voltage for 3.3 , 5 volt, powerbutton and so on.
          the +3/+5V regulator is not working pin 8 voltage is low what is the voltage on
          PL8701 PL8702 voltage ? you have to check the resistance to GND on the 2 coils , what is the voltage SIO pin 85 ?
            0V on the coils
            and SIO pin 85 is 0.8V too.
              Never did it before, so could do with some hints.
              Power button is part of the keyboard.
                Originally posted by DanFen View Post
                0V on the coils
                check the resistance to GND on the all Gray coils first after check the voltage on R3061 R3015 both side's SIO pin 26 74 14 108 voltage ? voltage on JRST2402 ?
                  on the attached guide pm_pwrbtn pin for volts here. measure and report back
                  +5vao +3vad +3vaddsw_on check both voltage and resistante to gnd (resistance without power )
                    Hey, thanks for the help.
                    Resistance to ground on coils:
                    PL8701: 0.5 ohms
                    PL8702: 1.5 ohms
                    R3061: 0V on GND and 3.2V
                    R3015: 3.2V (both ends)
                    SIO pin 26: 3.3V
                    SIO pin 74: 3.3V
                    SIO pin 14: 3.3V
                    SIO pin 108: 0V
                    JRST2402: 3V (but there's nothing here, is it on purpose?)
                    EDIT: C3003 seems to be hotter than other components, and voltage seems to play between 0V and 1.1V rapidly.
                    EDIT 2: PU8701 is extremely hot (can't touch more than a second as it burns, I've actually burnt my finger)
                      Short video attached.
                        resistance on pin 8 of bios ?
                          0.3 ohm
                            PL8701: 0.5 ohms
                            PL8702: 1.5 ohms
                            SIO pin 26: 3.3V
                            SIO pin 74: 3.3V
                            SIO pin 14: 3.3V
                            SIO pin 108: 0V
                            PU8701/2 low resistance there is a short on this part , remove one PAD of each Coils PU8701/2 & test again what side is short in Diode mode , remove C3003 & test out of the bed if it's short
                              remove the red marked jumper (clean with solder wick) and see if ic still get hot, if 3.3 and 5 volts comes on, see if resistance on coils has changed.
                                Yep, still frying eggs.
                                  Removed just one side of these coils, Pin2 of PL8701, and Pin1 of PL8702.
                                  So in diode (beep) mode:
                                  PL8701 pin1: beep
                                  PL8701 pin2: no beep
                                  PL8702 pin1: no beep
                                  PL8702 pin2: beep
                                  C3003 removed (coils still one pad off), in beep mode: beep on GND and no beep on +3V.
                                  I hope this is what you've asked for
                                    replace PU8701
                                      Will try to find a coil from a donor board. The problem is finding one that is exactly the same
                                      If I may ask, what makes you think PU8701 is the culprit and not PU8702 when the beeps result the same?
                                      replace PU8701
                                        This is what I have has this code on them, but I don't know how to read them:
                                        3R3 716 P1H
                                        3.3UH/6.5A 20% CYNTEC/PEUB063T-3R3MS
                                        What I've found from other boards I have laying around:
                                        2R2 1114
                                        4R7 1117
                                        3R3 310 E43
                                        R82 311 30H
                                        R24 308 VLT
                                        R36 309 RFD
                                        1R0 306 8XA
                                        4R7 310 C8M
                                        4R7 030 ZC7
