Lenovo G50-70 on off loop with ram
    Hello
    I try to help a friend with his broken laptop and I am hoping that some one here resonises the symtoons so maybe I can fix it. I already searched the forum and read many as I could, got also the schematics, so thanks for that.
    Laptop turns on and the screen/backlight does on off repeatedly
    With ram in other socket same, but slower frequently
    With double ram even slower
    a 4gb module blicks faster then a 8gb
    with no ram there is no screen blinking
    all is the same, with battery or ac adapter.
    battery is charging
    cpu turns on after a while.
    Around PQ40 I measure some capacitor on 139 ohm, is that shorted ?
    Best regards
    Jeroen
    This guy has the same but has a open end of hidden part 3.
    https://youtu.be/S5CqQbHN1-s
    Re: Lenovo G50-70 on off loop with ram
    Press down on the ram socket lightly in different places and see if the flickering stops
      tried on different places but there is no different in the blinking (speed)
        I feel a bit silly now, because I thought it had nothing to do with the bios due to the symptoms, but I was wrong. I read here on a old threat it was fixed by program a bios dump.
        That was also the case with this one !
        I lost serial number etc but assume it would not affect the performance
          still a bit strange, disk is 100% all the time, and by do a bios update it gives a warning about no ac-adapater and low battery, what is not true ..
          this bios https://www.badcaps.net/forum/newrep...reply&p=671177
          edit:
          sorted with this settings:
          [AC_Adapter]
          Flag=1
          BatteryCheck=1
          BatteryBound=30
          LauncherAcWarning=messagestringA02
          SecurityAcWarning=messagestringA02
          ;Flag (dwsDWS)
          ; default : 1.
          ; 0 : Don't check AC.
          ; 1 : Check AC.
          ;BatteryCheck (dwsDWS)
          ; default : 0.
          ; 0 : Don't check battery.
          ; 1 : Check battery.
          all ok now
            Can confirm here.
            Just had same model with exactly same symptoms (Also different "blink speed" with 4 & 8GB RAM), flashed BIOS via programmer, all working again.
            Cheers!
