benq gl2450 no power
    i have a problem with this screen , when i plug it to the elecricity it doesnt turn on and the orange light beside the power button "turns on" all the time .
    bytheway i opened the screen and didnt see any blown caps but in the logic board the main chip is so hot .............
    could some one help me ?
    Re: benq gl2450 no power
    any helppppppppppppppp
      What voltage readings do you get ?
        In the component view of Powerboard the bottom right corner is scorched below which is a smd Mosfet.Check that for shorts and voltage on all 3 legs.
        When you press power switch does orange light switch off ?
        Seems the smd mosfet and or 16pin chip below it could be defective.These components feed the LED backlight of the panel.
          yeah still orange color when i press it.
          so how could i messure the voltage of the 3 pins and what each pins should display in voltages ?
            Did you check the capacitance and the ESR of those 4 caps to the right of the main yellow power transformer? if those caps are bad, it can cause over heat problem.
            Bad caps can look normal.
            Also check the rectifier diode (I cannot read the designator of the Diode) that feeds the DC to those caps for the LED BACKLIGHTS Voltage booster circuit.
              zoom in to the mosfet you will see that i wrote the voltages in the right side
                here is the voltages
                  anyone could help me?
                    same problem, LCD in standby, voltage ok
                    Motherboard fail
                      You might want to read this thread, it's the large chip on the mainboard that is probably shorted.
                      https://www.badcaps.net/forum/showthread.php?t=67285
                      If you want to confirm it, check the resistance on the mosfet I circled in the photo which is 3.3v in and 1.8V out...i was getting approx. 80 ohms. I replaced that big chip twice to find out that it was the mosfet on the power board providing the 5 volts to the mainboard that was the problem. After I changed that mosfet on the power board AND the big TSUM chip, monitor came back to life....I also installed a small video card fan inside the monitor as it has a tendency to heat up.
                      If confirmed, you can either get a new board but change the mosfet on the power board first.
                      In my tinkering, I came across a board that had the same board number as mine but different monitor model number but I bought it. I arrived after I had fixed the monitor but the monitor was still open so I tried it and lo and behold, it worked! Didn't need it anymore, so I put it up for sale on Ebay http://www.ebay.ca/itm/202291559401?...84.m1558.l2649
                        Sorry, in my previous post:
                        should have read
                        on the power board providing the 3.3V to the mainboard.
